Old 10-22-2015, 07:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Power outlet in center console not working
Old 04-13-2011, 11:51 AM
DansZJ
DansZJ's Avatar
Makes sense about the coins - I hadn't thought of that being a possibility.
While we're talking about these sockets: I would like to keep my USB plug in the socket when I'm not using it, but the socket is powered when the key is off. Does anyone leave theirs plugged in (without anything else plugged in) and it NOT drain the battery?
DansZJ is offline
Old 04-13-2011, 12:32 PM
obxdude018
obxdude018's Avatar
I unplug mine just for the fact that I don't want to take a risk on draining the battery, I had enough charging system problems as it was. All these new cars draw some milliamps when the car is just setting, it shouldn't be enough to drain it over a few days, but if you let it sit for a few weeks don't be surprised if its dead.
obxdude018 is offline
Old 04-17-2014, 08:04 PM
Marley07
Marley07's Avatar
Default Genius!
Originally Posted by 05windviel
also be sure to keep the plug on it because sometimes coins can get inside of the socket and cause the fuse to blow thats why they have the nifty cover
After testing the outlet with a multimeter and confirming it worked, I stumbled upon this suggestion... Nevertheless, you were correct! In my case, it was a dime.
Marley07 is offline
Old 10-01-2016, 09:09 PM
cmd
cmd's Avatar
Thanks for the advice......pennies fit too��
cmd is offline
Old 12-09-2018, 06:35 PM
Steven Easton Jeter
Steven Easton Jeter's Avatar
Default Cannot Locate the correct fuse
Hi guys, I am having the same issue,
my center console Aux Power Plug is not working. I think i just burned the fuse up. I notice where the previous answer stated it was Fuse #64, but my Power Distribution Box doesn't have a fuse #64. Anyone know where this fuse is located? I have a 2011 Ford Mustang V6 Coupe (Non Convertible).
Steven Easton Jeter is offline
Old 12-09-2018, 09:55 PM
jnk3846
jnk3846's Avatar
http://knigaproavto.ru/shemy/en/ford...x-diagram.html
jnk3846 is offline
Old 05-25-2022, 12:13 PM
Junior602
Junior602's Avatar
Default Center console
Originally Posted by Hotwheelracer
Just got the car a month ago, tried to plug my charger in the power oulet in the center console, no power. Works fine from the one in the dash. Is this a fuse issue? Would there be a fuse dedicated to just this outlet because everything else works?
Hi there peeps. New here. Just wondering how hard it is to disassemble the center console to get to the 12v outlet? Want to take it out and replace it with a USB version that hooks up to my stereo. To be able to access android auto and whatnot
Junior602 is offline
Old 05-30-2022, 05:04 AM
bl817
bl817's Avatar
its not terribly difficult. its the first part to come out to get to the stereo bezel. IIRC, the 2 rear most outer screws are removed then there are 2 in the bottom of the compartment under the lil piece of "carpet". pull the parking brake up, remove the shifter trim and **** (if 5 speed) then just lift up from the back and over the park handle. you can then unplug the power outlet and remove the console. good luck
bl817 is offline
Old 10-15-2022, 01:50 PM
Lizzyque
Lizzyque's Avatar
Default Help
Originally Posted by Twstones
In case you haven't check, the center consul is fuse #64, and the dash power point is fuse #61 Both are in the power distribution box, under the hood, and they're both 20 amp.
how do i figure out the cause of the #64 fuse blowing
Lizzyque is offline
Old 09-04-2023, 01:43 PM
danishgem
danishgem's Avatar
Default BINGO coins
EXACTLY MY PROBLEM!!!! You saved me a lot of time, money and stress.
danishgem is offline
wolfsmane
12-30-2015 06:54 AM
billcrews81
04-04-2013 09:53 PM
Rylay
06-14-2012 03:16 PM
Burnsy
06-17-2008 04:38 PM
slikflop
08-15-2007 03:23 AM
Quick Reply: Power outlet in center console not working
