V6 swap to V8
It isn't extremely hard to find a V6 and equivalent same year GT in an '05, '06 or '07 with a $2k - $3k price spread. Even if you could find the engine, tranny, rear, electronics and suspension parts for $3k (which would be a bargain) you have one heck of a lot of work to do.
so considering a mustang v6 with an 8.8 (assumed they already had it bc it is 100% necessary when going to a v8) would require (minimum):
v8 engine
-intake, alternator, radiator, motor mounts, fuel lines, ac hook-up, exhaust
computer
-wiring harness, gauges
GT suspension
-GT brake rotors and bracket, at least stock GT shocks and springs, sway bars
Drivetrain
-driveshaft, transmission, clutch/torque converter
thats generally the stuff needed. although it may seem like a ton of stuff to gather and make sure it will all work properly, it is not the biggest thing in the world. if you are someone who has limited to beginner experience working on cars i would not even think about it, but for those who know about cars and all the other "little" things that go along with this while also being willing to put forth the time and effort into it, id say go for it.
The beginners, dont hurt yourself, buy a GT.
The easiest way to do this, although maybe not the most cost effective (debatable) it to buy a barely totaled/wrecked GT and swap the parts over. this will save time looking for compatible parts, frustration, and in some cases money. money because all the parts are already there, you may have to get a few things. no time and money wasted buying new or looking for used stuff on top of the other things you forgot lol
i have not personally done this, but talked to many that have and this seems to be the way most shaped up. i will eventually do this (note 8.8 and GT brakes upgrade) but im holding off till i can get a hold of a 5.8!
v8 engine
computer
GT suspension
Drivetrain
Once my car is paid off I'm buying a wrecked gt swapping all the necessary parts over, with buying a wrecked gt as well, if there are parts that are still in decent shape you can sell them to try to recoupe some of the costs of buying the car.
v8 engine
computer
GT suspension
Drivetrain
v8 engine
computer
GT suspension
Drivetrain
You do need the entire v8 engine and accessories (including air intake box and tube or a CAI), transmission, flexplate and adapter, torque converter, cooling system hoses, fuel line hose section from fuel rail to fuel line under fender, pcm (for your year/pcm), engine wiring harness (for your year/pcm), power steering steel line, a/c lines from the compressor, exhaust of your choice. Then, a tune to disable PATS until you get it reprogrammed by the dealer.
The rest of what's in your V6 can be used, including radiator, instrument cluster, driveshaft (automatic), rear end (although you should upgrade to a 8.8), brakes, suspension, etc.
That's about it.
The best bet is indeed to get a wrecked donor GT with engine/drivetrain intact, especially if the rear end is good, too.
Ok, so you drop in the V8 plus all of the ancillary hardware you need to make it work, which by the way almost surely can't be done for a price that would be less than just buying a GT. But anyway, you do all of this so that you can have the V8 but according to your post you can continue to pay V6 level insurance premiums.
Have you stopped to consider what happens if you get in a wreck and have to have some engine work done? Your insurance company is going to drop you and the repair bill is all yours buddy. lol
LMAO
I am in th position of spending roughly 3k for suspension and brakes, plus wheels and tires, I can do the swap on my own so I don't have to worry about labor costs and I love working on cars so it's not a waste of my time and I have seen wrecked gt's go for sale around 3k at auctions, then you can sell the 4.0 parts from your car and possibly some of the parts off the wrecked car. It's much easier to go and buy a gt, but it's not as fun as seeing your car transform from a v6 to a v8, plus you can learn alot about your car by doing the swap.
