oil choice?
#21
Thanks guys! I was just speaking to my hubby about this subject. I have only owned my 2010 for about a month. I did not really know the difference with the synthetics vs. traditional oils. If I am reading correctly, you guys really suggest it....
#22
I can't say that we "suggest" it, I personally say that the car COMES with synthetic blend from the factory and that the Owners Manual for my '07 implies that you can use ANY oil; dino, blend or full syn. Either of the 3 will provide equivalent performance and longevity provided you change each one at the correct frequency. I use full synthetics in my Stang and SUV because I don't want to change the oil every 2-4 months, period. It really has nothing to do with one being better than the other. If you use good ol' dino oil and change it with a good filter every 3k miles, your car will last as long as the guy using the blend doing 5k-7k mile frequency changes or the guy using full syn doing 10k-15k mile changes. There's just too much hype from the oil companies to make normal lay folk see straight.
#23
#26
Not going to start an oil war debate buy telling you what I know is for sure crap but I will tell you what I know from personal experience works.
Dino Oil = Chevron or Chevron Delo, Quaker State
Blend = Chevron Delo, Motorcraft or Quaker State
Full Synthetic = Amsoil, Royal Purple or Chevron
Note: Since Quaker state and Pennzoil merged I don't now if they have kept the oils to there original specifications or bottle the same stuff under different brands. At any rate I quite using it when they merged.
I personally run:
Amsoil 5W30 100% Synthetic Motor Oil
Motorcraft FL-820-S or Amsoil EaO11 Oil Filter or
FilterMAG HP-365 Magnetic Oil Filter System
I personally run:
mungodrums
Suspension
09-24-2015 10:12 PM
