Time for a new suspension
What are you looking for suspension wise? Is the car drag raced, road raced, or not raced at all. How involved do you want to get with it? There is a lot of options we just need to know what you want out of the car. Let me know if I can help.
this is the set up I chose:
Tokico D-Spec adjustable strut and shocks
Eibach Sportline springs
J&M CC plates
J&M adjustable panhard bar
I want a safe drop with no clearance issues since i have 18x10" wheels in the rear, and I want to be able to take sharp turns faster with less body roll and keep my wheels planted for both street and drag racing. Also is there anything else I need for the suspension to work properly?
Nothing is finalized yet so I am willing to change some of my ideas. if you think what i chose isnt a good choice let me know, you prob know a lot more than I
J&M CC plates
J&M CC plates
J&M CC plates
J&M CC plates
J&M CC plates
Depending upon how much those springs drop you it may be necessary to get an adjustable UCA to change your pinion angle. I have the FRPP springs on the rear of my car (stock springs up front) and the pinion angle measured out to specs so I haven't had to adjust it yet. The adjustable UCA is much easier than adjustable LCA because you only have one point of adjustment.
I would add both the J&M HotPart LCA and adjustable UCA to your list. The HotPart arms will give you better launch because of the stiffer poly inserts, while giving you good cornering still because of the poly ball they use.
So I would add to your list:
Relocation brackets (can get them from J&M)
HotPart LCA's
HotPart adjustable UCA
1.6 in the front and 2 in the back its not too much of a drop because my area has bad roads, and thanks for the tips JimC I will add those to my list unfortunately i will have to save up a couple hundred more but im sure the wait is well worth it
musnicki
09-23-2015 07:11 AM
