V6 RPM limit
Old 07-22-2011, 01:38 PM
Spad
Spad's Avatar
Default V6 RPM limit
What is the RPM limit on the 4 liter V6? Modifying the engine beyond the stock RPM. Thanks
Spad is offline
Old 07-22-2011, 03:30 PM
Nuke
Nuke's Avatar
RPM LIMIT or the factory default redline?
Nuke is offline
Old 07-22-2011, 03:54 PM
Spad
Spad's Avatar
How about both?
Spad is offline
Old 07-22-2011, 10:59 PM
JCON
JCON's Avatar
I have mine set at 6300. Don't know the limit
JCON is offline
Old 07-22-2011, 11:28 PM
Nuke
Nuke's Avatar
I'm not sure anyone knows the upper limit. But on my GT, the factory rev limiter is set at 6250. Brenspeed reset it in their tune to 6800 and I moved it back down to 6500 RPM. And I bounce off it on occasion.
Nuke is offline
Old 07-23-2011, 12:43 PM
MustangFirstCar
MustangFirstCar's Avatar
I have mine set at 6000 to be careful. I wouldn't be surprised to see people push 7K without problems on occasion.
MustangFirstCar is offline
Old 07-24-2011, 12:17 AM
JCON
JCON's Avatar
7000 might be a tad higher. I would say you can push as far as 6500 on stock internals, but would go above that. you'll most likely start bending/breaking internals.
JCON is offline
Old 07-24-2011, 02:15 AM
Spad
Spad's Avatar
Thanks for the info. I have a particular exhaust system in mind and it will sound good at higher RPM. Spad
Spad is offline
Old 07-25-2011, 10:48 PM
up_yours_7
up_yours_7's Avatar
Mine will go and once it gets to high it will pop out of gear did it once
up_yours_7 is offline
Old 07-26-2011, 01:47 AM
tx_zstang
tx_zstang's Avatar
The 4.0L valves tend to 'float' as rpms get up there. Upgrading the springs would help that and allow a little safer rev range.
tx_zstang is offline
Quick Reply: V6 RPM limit
