Intermittent Starting Problem - Ideas?
We've got a 2006 Mustang 6cyl with 88K miles on it. About 5 months ago, it began having an intermittent starting problem. Turn the key, the dash lights go on, but the engine wouldn't crank - just clicking. After a couple of tries, it would start. And other times it would start just fine on the first try.
We took it to the Ford dealer thinking it was a starter and they said it was just a bad battery. We put a new battery in and everything was fine for the next 5 months. Now, the problem is back. Sometimes it starts on the first turn of the key, other times the engine doesn't crank at all. We'll keep trying and eventually it will start.
I decided to troubleshoot the problem by trying a new battery, since that seemed to fix it last time. Nope, the problem is still there.
I know it sounds like a starter, but it just seems strange that we had the problem months ago and then it went away with a new battery and now it's back again.
Does anyone have any ideas? Thank you in advance.
Sounds like you might have a bad alternator, our mustangs OE alternators are notorious for shoddy reliability, especially the earlier model years.
Get yours tested, I believe autozone/napa/o'reillys does it for free.
Throw some jumper cables on it.
If the problem persists while being jumped it's the battery/alternator. (Rules out the starter)
Autozone etc can test batteries, starters, alternators, etc. while they're still on the car...
but they aren't always accurate.
bryan616fl
01-25-2019 09:07 PM
