P0302 misfire
P0302 misfire
about a minute i started my car (2007 4.0)yesterday afternoon it started to run rough and shortly after the CEL light came on. when i got home i saw this code. so i pulled that wire from the coil and restarted and it was the same so i pulled that plug and changed it no better. changed the coil & wires- no better. what next...lol ? thanks
here's an update.... i hadn't checked the code after the parts replacement but wanted to clear the CEL and when i connected the code reader it's now a 2197 sensor stuck, bank 2,1. could have the o2 sensor gone bad in the time i drove the car when the cylinder 2 wire, plug, coil position went bad? thanks again.
it still ran rough after clearing the 2197 code after i changed the coil & wires. not as rough as with the 302 code though. i only ran it a minute after, not long enough for another 2197 to come in but long enough to feel it running rough. i'll run it again tonight until a code (most likely 2197) comes in. i'm figuring if it does i'll need to change the o2 sensor.
Omgitsa88Stang
10-05-2015 07:33 AM
