Insepction coming up will I pass and emergency brake cable guide?
So I need to get an inspection soon, The only mods I have is a Ford racing CAI and a tune, should I tune to conformance, street or racing ( I assume street) and will it pass? or should I put in my old air box and tune stock. Also My Ebrake cable broke, I have a new one does anyone know where I can find a manual or instructions on how to change it?
Thanks
Thanks
My crystal ball says you will pass with the current loaded tune. However, I reserve the right to be incorrect and no way liable for your cars failure to pass inspection and for any hardship or expense incurred by you.
This should help with the e-brake... http://iihs.net/fsm/?dir=108
Depends on the tune. Depends on if the rear O2 sensors are off and you have 3 "Not Ready's". Depends on the inspection, if they check for OBDII readiness.
Reverting to stock intake and tune, if you have them, is a sure-fire way to get things in a more known and more-likely passable state. But give it a couple days and drive it around before going in for the inspection.
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
Fast-Hands
08-19-2015 06:54 AM
