Is there an oil separator just for V6??
I agree the majority of the oil comes from the passenger side of the V6. The PCV is mounted to the passenger side valve cover. The info on the heated PCV input came straight from the Haynes Manual. I will check out the air/oil separator from Home Depot...thanks!
Good info. Still deciding what to do. I can't believe that there is not a "Plug and Play" oil separator for the V6. Were not more V6's made that V8's? Guess more V8 owners mod their cars that V6'ers. I like that stock look under hood.
Can you post a pic of your separator? Like to see how you fit it in. I want to cut the passenger side PCV tube in half and install the separator right there without having to use oil line hoses or mounting on shock tower struts.
You can easily modify the separator for the V6. On the 4.0 you put the separator on the PASSENGER side and not the driver side like the V8.
I have the UPR on mine, and while it is supercharged you put the separator in the same spot. It is the aluminum canister on the shock tower, passenger side. I just used some oil resistant hose and connected it to the PCV and the port on the back.
Looks great guys...how about non-blower motors that spliced right side PCV line in half and have kept it "in-line", without having to mount on shock tower? Looking to cut and insert right where white label is on PCV line.
JLT wrote me back this morning. Here's what was said:
"Yes, we have a test unit in the field and should be releasing a kits in the next week or so. Keep an eye on the web site.
Thank you,
Jay Tucker"
JLT Performance
757 335 1940
Jay@JLTtruecoldair.com
www.JLTtruecoldair.com
Thank you,
Jay Tucker"
JLT Performance
757 335 1940
