BBK 70mm Throttle boby
Old 02-05-2013, 08:18 PM
Nuke
Nuke's Avatar
Originally Posted by JoeRoma5
Preference on street tires?
With the 4.0 and even with a few bolt-ons, you don't have a lot of power to worry about hooking up so your choices for tires are a bit more. Just be sure that you don't get a summer tire which will turn into a rock in your cold weather.
A lot of guys like Nitto's but I don't have any personal experience with them. I suggest using sites like tirerack.com for their tire ratings to begin your research. Considering your location, a good all-season should suffice but be aware that all season tires suck in snow and the Stang's light weight over the rear end causes the Stang to handle like garbage in slick weather compared to other RWD vehicles.
Nuke is offline
Old 02-06-2013, 07:03 AM
JoeRoma5
JoeRoma5's Avatar
Haha yeah i have noticed. I was planning on storing it this winter but it sounded like a lot of effort so i take it out whenev its not snowing. Besides, its not like its a gt500 or anything haha
JoeRoma5 is offline
Old 02-06-2013, 05:46 PM
Nuke
Nuke's Avatar
If you really do intend on driving it thru the winter where you are, I'd recommend a set of dedicated snow tires and about 150# of sand in the trunk. A cheap set of takeoff wheels would make the swap a simple task each winter. The Stang is NOT a good vehicle in the snow, although the 4.0L won't get you into QUITE as much trouble as the 4.6 and 5.0 will.
Nuke is offline
Old 02-07-2013, 04:08 PM
157dB
Cut & Paste Expert
157dB's Avatar
The new Mickey Thompson Street Comp tires...
www.jegs.com
157dB is offline
Jb145700
08-21-2022 06:37 AM
Luke9222
10-22-2015 11:55 PM
UrS4
10-03-2015 06:23 AM
guitarman376
09-30-2015 05:54 PM
JDWalton
09-24-2015 08:47 PM
Quick Reply: BBK 70mm Throttle boby
