Questions on procharger 4.0
Can't help wanting to upgrade the 4.0 and give it some *****! Lol
Ive heard good things about the procharger, I wanted to see what others have to say about it. I have seen multiple kits online, one claiming 400hp! That would be nice Is this safe on the 4.0? If not.. what is? I have no mods as is, just researching before I make any rash decisions. I am definitely looking to go supercharger, and I heard the procharger was the best..
I'm not sure you can get 400hp on the 4.0, but I have the ProCharger and I'm happy with it so far. The car is VERY fun to drive! I have no experience with other brands so I can't comment in that regard.
Check out my ProCharger thread:
https://mustangforums.com/forum/pipe...r-project.html
Thanks. I'll be glad to answer any questions you may have. If you really want 400hp then get a GT.
Looks like a lot of people have been upgrading the heads and cams, then adding the procharger.. im
Thinking of going this route in the future. Im assuming it is a lot safer for the engine, plus you get great hp and tq gains.
Honeslty, you can't really answer if a blower is a "safe" setup. Bottom line, you are putting more load on your engine at all time, and its NEVER good for the engine. However, they are extremely fun, and if you drive smart, add the necessary supporting mods, and get a solid tune, you should be more than fine. A procharger is a centrifugal pump, which is extremely efficient (right below a turbo), and you can make great power with one. However, if your goal is to feel more "umph" down low, and care less about big numbers, you may want to considers a positive displacement style blower (like the Termi's and the GT500s). A PD blower will build torque and power in a much more linear fashion, and will feel more like a big block NA v8 compared to a centrifugal blower. Also, the PD blowers are basically install and drive, while prochargers and vortechs require maintenance intervals. Hope that helps!
@ aenima4six2
Thank you for the write up, you made some valid points. I have some time to decide what option would work best. Is there an ideal procharger kit to go along with upgraded internals and a good tune? As you said, there is always a risk.. but Im trying to get an idea of what would work best.
@ aenima4six2
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
