Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: How to Replace Radiator
Step by step instructions for do-it-yourself repairs.
Radiator Leak
Hey Scotty104, I am seeing the exact same leak. It is dripping from a bolt with a heater cable bracket on it. Noticed it after replacing the water pump. Did you find the problem? The bolt is attached to what looks like the engine mount and the bracket is holding the heater hose that comes off the water pump. I have checked to see if it is runoff from some other place and the answer is no. I have been searching this forum for hours until I found your Q and it looks incomplete. Everybody is hung up on the thermostat housing.
Check above that bolt, the lines/hoses on the side of the engine, and yes, closely at the thermostat housing and temp sensor in the top of the housing.
I replaced out the thermostat housing a year ago and is working fine. However, I now have a external head gasket leak, which is slowly leaking coolant onto my garage floor. Due to being external, the engine is not in jeopardy. I'm not worried about it, just the coolant leaking out and the smell is annoying. :/
Update: Well everybody was hung up on the thermostat housing for good reason. That was my problem but I was too stubborn to believe it until I could see it. By looking for leaks with engine running and under pressure was deceiving on where the source was. Finally I got a radiator pressure tool on loan from AutoZone and with pressure built up with engine NOT running I was able to get into a position where I could first hear an air leak then finally see water bubbling out of a crack in the housing. Sure enough it was there but was not visible when pressure was released. Even once removed it looked good. Replaced it and resolved my problem. Air pressure also revealed a few hose leaks that were resolved with a few turns of the clamp screw or replacing factory clamp with a screw on clamp. I sure do appreciate everybody's help and suggestions on this site.
Thanks one and all!
Thanks one and all!
My 2009 overheats
I have a 2009 Ford Mustang base model. We've changed the thermostat, thermostat housing, temperature sensor, the water pump is good, new battery....stillll overheats. I was told it could be a clogged heater core, CCRM, head gasket (blown), or intake manifold. I cannot afford to get all these parts replaced. Is there anyone that's had this problem? It has 88,000 miles on it.
I replaced out my thermostat housing/sensor and no leaks.
I have an external head gasket leak. It just leaks into the "V" of the engine and then eventually drips out onto the ground. Fortunately, I don't have any issues with overheating.
When you replaced the thermostat housing, did you flush out all of the coolant and then run water through?
Glad you got it fixed, Yumazona. There are just some things that are so prevalent with these vehicles that we can't help pointing them out. Nine times out of ten the source of a coolant leak is the housing.
THE LEAKING BOLT FROM HELL
Hey guys, great forum. My heater stopped getting warm a few weeks ago, I noticed the reservoir was low, added water, heater worked again, but the reservoir was back down in a few days. I read about the crappy plastic thermo housing, but couldn't see a leak anywhere & no drops in the driveway. Today, I FILLED The reservoir to the cold line, started the engin, almost immediately, it was dripping pretty fast underneath. I grabbed a jacked it up a bit, & grabbed a flashlight just to trace the drips directly to the same bolt from hell & did not see anything above it. Can anyone confirm that it IS indeed the crappy plastic thermo housing, even if it looks like the damn bolt!
It's hard to tell where that bolt is with that picture being a close up. Is it the alternator bracket? Looks like an engine mount maybe?
But water will run so more than likely it is the thermostat and it is simply running to the lowest spot to drip. You can see evidence of water flowing that way.
The thermostat housing usually splits on the back side. What does it look like around the thermostat housing?
bradleyb
11-27-2015 07:50 PM
