Forced Induction on 4.0L waste of time?
I had a question, and wanted to see what everyone thought of a forced induction, either super or turbo charger.
My struggle is the speed limiter of the 4.0L engine and if the amount of money would be wasted because of the top speed. I've heard of the top speed being defeated with a tuner but how do you measure the speed past the speedometer?
Thanks beforehand for the info.
Have a buddy with a turboed 06 v6 pony and it sounds absolutely wicked. I love that turbo whistle along with the v6 engine, to me it just sounds meannnnnnnn. Traditionally superchargers are more reliable than turbos. With a supercharger you have instant power, a turbo has to build up power. And with a new drive-shaft (as our stock 2 piece drive-shafts on the 4.0 have a reputation of destructing above 115 I believe due to the u joints being pressed in with no C-clips((I believe it was from the 07 models forward they began installing C-clips to fix that issue)) but still our drive-shafts are defiantly not the best for high speeds) and a 8.8 axle (stronger and no more 1 wheel peel) you should be able to safely achieve speeds above the 120 on the dash.
As far as your speed, electronic speedometers with a display easily fix the issue of your speed.
(or GPS lol, that would probably be the simplest method.)
I was merely asking the question of what people thought of the 4.0Ls and forced induction. You stated you like your turbo, could you be a little more descriptive than "...my favorite"?
I'm not an idiot, I know how turbos and superchargers work, I'm asking for opinions and what people have done about the limiter.
In what way? The 4.0L have a governor at around 115MPH. You can remove it with a tune but bad things happen at around 120-125MPH. The driveshaft on the V6s don't hold up to terribly well at those stress levels.
Anyways, I originally wanted to get people's opinion on whether FI was a waste of time on a 4.0L. I'm not asking how to do it, rather for those who've done it/gone through the process of looking at it, if it was worth it in their eyes.
The portion about the speed limiter was a question that I didn't know the answer to. That was more around how the speedometer read over the 120MPH the stock gauge cluster has. I've sense researched and learned you can install a different cluster, it just needs to be re-calibrated. I am well aware I would need to probably upgrade my driveshaft and defeat the limiter with a tune.
So again, do you guys think it was worth it going FI, for the overall costs?
I thought it was worth it on my 2006 - added the Xcharger Xtreme, and the car was running mid 12's. Surprised a lot of people at the track (was especially nice beating a Camaro making a lot of noise - he didn't want to talk afterwards).
