2005 mustang will not start
Old 06-08-2013, 05:25 PM
clewis0316
clewis0316's Avatar
Default 2005 mustang will not start
My wife's 2005 Mustang would not start this morning. Every thing works, lights, gauges, windows, alarms. When you turn the key on to start it the starter never kicks in to start. There is not even the sound of the relay to kick it in.
clewis0316 is offline
Old 06-11-2013, 08:56 PM
99GTvert
is my username.
99GTvert's Avatar
This is for the 4.0, right? (I moved it here from FIF based off of your post history)
99GTvert is offline
Old 06-12-2013, 05:01 PM
Nuke
Nuke's Avatar
Original battery? Original alternator? Both suck from the factory. It's possible that there is sufficient capacity to light dash lights but not enough to crank the starter. This is quite common with the S197 charging system.
Do the lights dim when you turn the key to try to crank the engine or blow the horn? If so, it's almost surely the battery, which would also mean you should consider a PA Performance alternator and NOT a Ford new or rebuilt unit.
If the lights DON'T dim, then you likely have another issue going on.
Nuke is offline
Old 06-13-2013, 11:49 AM
CORPORAL
CORPORAL's Avatar
Check for any codes but my guess would be crank sensor.
CORPORAL is offline
Old 06-21-2013, 07:37 PM
Boneman
Boneman's Avatar
Another thing to check... you don't mention if it's manual or automatic....
If it's auto trans, possibly the neutral safety switch is hanging up...
If manual, could be the switch on the clutch.... I don't know the technical term but it's the one that forces you to push the pedal all the way down before it will engage the starter.
Just a couple of other possibilities that may be a bit easier and more economical to rectify.
Boneman is offline
Old 06-22-2013, 01:50 PM
Nuke
Nuke's Avatar
As another possibility, I think that if the key loses it's programming (damned electronic keys...) the engine won't crank or will crank but not fire.
Nuke is offline
Old 06-23-2013, 06:44 AM
Boneman
Boneman's Avatar
Another case of superfluous electronic B.S. making our lives ever more miserable.
Boneman is offline
Old 01-05-2014, 03:05 PM
bradentoncissy
bradentoncissy's Avatar
Default 2006 wont start
It is getting power and will start after turning key many times. After researching, it might be neutral safety switch. Where is this?
bradentoncissy is offline
Old 01-05-2014, 03:12 PM
bradentoncissy
Default 2006 automatic wont start
I have all power but it wont start. After researching I think it might be the neutral safety switch but I cant find this part. Can you tell me where it is located?
Old 01-05-2014, 03:46 PM
tx_zstang
tx_zstang's Avatar
manual or auto?
Manual is located on the clutch pedal.
Auto is the shifter itself; try it in neutral in addition to park. My stock shifter on my 05 broke so that it wouldn't work properly in park.
tx_zstang is offline
ShaneB26154
35
03-04-2021 04:05 AM
Jgabbard
05-08-2018 03:37 AM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
ericunderwood
08-11-2015 03:40 AM
Quick Reply: 2005 mustang will not start
