06 heater core - MustangForums.com
Old 06-26-2013, 12:21 AM   #1
TheBiggestCat01
Angry 06 heater core
I've been attempting to replace my heater core and so far it has been less than fun. I'd rather replace the engine again(I've done that). So far I'm just shy of pulling the entire dash its mostly unbolted and if it would've came out on the first couple of tugs it would be out. If anyone can she'd some light before I break out the sawsall I'd appreciate it.
TheBiggestCat01 is offline   Reply With Quote
Old 07-01-2013, 12:13 AM   #2
flyhigh@mach1
flyhigh@mach1's Avatar
Have not done that work. Are you using any manuals? Let us know how it turns out.
flyhigh@mach1 is offline   Reply With Quote
Old 07-01-2013, 03:07 PM   #3
Stang-aholic
Stang-aholic's Avatar
I havnt heard of this happening but Im sure someone around may know some more.
Stang-aholic is offline   Reply With Quote
Old 07-01-2013, 03:24 PM   #4
Derf00
http://iihs.net/fsm/?dir=461&viewfile=Instrument Panel.pdf
Review the diagrams and make sure it's all disconnected.
Heater cores are never fun. Did one way back in high school (shop) and never again. There are no easy ones either. All of the ones I know require removal of the dash...
You may have to disconnect the steering shaft if you haven't already? That is the one thing most people try to avoid doing.
Good luck.
Derf00 is offline   Reply With Quote
Old 07-02-2013, 12:07 AM   #5
TheBiggestCat01
Yep steering has to come out. Whole dash has to come out
Old 07-02-2013, 12:13 AM   #6
TheBiggestCat01
If you're considering this you better be committed its not for the weak!�� part of any challenge is knowing the out come. So knowing that yes, you do have to completely remove the whole dash to access the unit should get you started in the right direction.
Old 07-22-2013, 02:50 AM   #7
YoungBlood
YoungBlood's Avatar
Doing this on my Jeep right now... it sucks
YoungBlood is offline   Reply With Quote
2007 Won't stay running -- Possible electric problem Seanam V6 S197 General Discussion 5 10-04-2015 11:15 AM
Please help! 10 Check engine codes mrtrodonet V6 (1994-2004) Mustangs 1 09-29-2015 12:13 PM
02' GT Convertible, Need help choosing intake manifold. Calizic 4.6L (1996-2004 Modular) Mustang 5 08-28-2015 02:46 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
Trans issues codes P0732 P0735 P0775 Mnuckolls 4.0L V6 Technical Discussions 3 08-09-2015 09:54 AM
