Thermostat Housing... I think.
Old 02-28-2014, 07:48 AM
Boneman
Boneman's Avatar
Default Thermostat Housing... I think.
Procured my '05 pre-owned in 2007 with 52K miles on her. Kept a close eye on the thermostat housing as I was aware of this being an issue. My thoughts are that because of the mileage, could very well be it was replaced prior to my ownership of the car
Fast forward to this week... and at 146K miles, methinks it's finally begun... at least that's what it seems.... Have the new one... will install over the weekend. Doesn't look like an overly difficult job.
To make it easier, I suppose you should pull the throttle body. Well... if that's the case, I'll clean that too in the process as it's due.
Quite a bit of leakage though... and I'm wondering (as it would be just my luck) if the water pump were failing too. We shall see!
Boneman is offline
Old 03-01-2014, 06:07 PM
2005Redfire6
2005Redfire6's Avatar
Okay? Lol
2005Redfire6 is offline
Old 03-01-2014, 09:43 PM
Nuke
Nuke's Avatar
I'll put money on just the t-stat housing. We don't hear about water pump issues hardly at all compared to t-stat housing leaks.
Nuke is offline
Old 03-02-2014, 09:13 PM
Boneman
Boneman's Avatar
Well the housing is replaced... a bit of a hiccup pursuant to a missing plug in the 2nd, unused sending unit hole....
Interestingly enough, the old housing seemed to be fine... it was more the gasket between the housing and the block that was leaking to beat the band.
Water pump seems to be just fine. (touch wood!)
Boneman is offline
Old 03-17-2014, 08:32 PM
bfunke
bfunke's Avatar
The problem is usually the housing cracks not a gasket issue.
bfunke is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
Dokilar
15
10-16-2015 08:13 PM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Thermostat Housing... I think.
