alternator issues?
Old 04-24-2014, 09:17 AM
  #21
TBuckTex
TBuckTex's Avatar
Teetertotter, I wonder if the spark plugs are creating my problem. I put in E3 plugs and that may be the issue. Going to go back to motorcraft plat and see what happens.
TBuckTex is offline
Old 04-24-2014, 09:40 AM
  #22
teetertotter
teetertotter's Avatar
Let us know if Auto Lite OEM plugs was a further cure to your symptoms if you decide to go back. All I know is that my new mechanic, of one year+, diagnosed not having OEM plugs in my 4.0L. Same spark plug coils are original.
teetertotter is offline
Old 04-24-2014, 01:12 PM
  #23
TBuckTex
TBuckTex's Avatar
I will let everyone know. The plugs i believe are Motorcraft AGSF-24F-M finewire platinum set at .054. I changed my originals at 92k, they looked brand new when I did!
TBuckTex is offline
Old 04-25-2014, 01:02 PM
  #24
jlopez07
jlopez07's Avatar
Im going to be running my car again at the track next Friday for the second time ever. Everything has been checked on my car as far as fluids amd routine maintenance got done on it as well Wednesday. Plugs changed, oil, fuel filter. Only mods I have on my car are bbk intake, shorty headers, 3.73s, underdrive pully and tune. Anything I should be worried about when running? Blowing my engine, timing chain, etc etc?
jlopez07 is offline
Old 04-28-2014, 09:31 AM
  #25
TBuckTex
TBuckTex's Avatar
Changed plugs out for the Motorcraft over the weekend. No improvement. I think it actually ran better with the E3 plugs! Oh well, will run these for a while and see how it goes. With the E3 plugs it was a bit more agressive to start and run.
TBuckTex is offline
Old 04-29-2014, 03:53 PM
  #26
teetertotter
Well, I guess you gave it the ole college try. Sorry to hear you have the same condition.
Old 04-30-2014, 07:43 AM
  #27
TBuckTex
TBuckTex's Avatar
Thanks. Going to change the upstream O2 sensors next. The checked out good (within spec) but its the only thing I haven't replaced yet after 130k miles. Honestly, I believe the problem to be electrical, but cleaning the grounds didn't help. Any electrical strain (fan, roof, blinkers even) causes the idle to change and the engine to bog slightly. Been trying to get this right for a year now, guess its just a pipe dream to think that it will run as well as it did for the first 8 years. But not giving up yet!
TBuckTex is offline
Old 04-30-2014, 10:16 AM
  #28
teetertotter
TB, the only other thing I can think of is disconnect the battery for a few hours.....reconnect for system to relearn and see what happens.
Picked up mine from local front end shop this morning as they took off the snow tires and put on the summer one's. Both sets tires have their own rims. He said there is a loose lower ball joint on the left side that needs replacing. I am waiting for him to call for estimate.
I should have just left the car with him and have that done today, if he could fit it in. My ABS light/traction control is intermittent and nothing I need to take care of right away.
I still hope you find out what is going on with yours....like pulling hairs!
Old 05-21-2014, 11:53 PM
  #29
TinPony
TinPony's Avatar
I think I need a new alternator on my 07 4.6. My gauge show not charging and I hear a whining like maybe the alternator bearing... Does anyone have any tips on this do it yourself job. Looks like a lot of parts need to come off to get at it. Any input or direction would be appreciated. Thanks
TinPony is offline
Old 05-22-2014, 09:07 AM
  #30
TBuckTex
TBuckTex's Avatar
I changed out mine on V6 and was simple, about 20 minutes. Not sure on a V8 though. Just have a nice long bar handle on your ratchet to be able to loosen the tensioner on the belt! The rest was easy. Oh and having the dielectric grease to put on all the connections is always good.
TBuckTex is offline
Quick Reply: alternator issues?
