AC Control Switch
Old 07-09-2014, 12:44 PM
shelooga
shelooga's Avatar
Default AC Control Switch
so we hit 99 yesterday. i do not enjoy sticking to my seats.
after some research, it sounds as if my ac switch is my issue. blower works, all vents work, its just piping hot air. the little indicator lights up, but my compressor isnt turning on.
does anyone know if this is a complex fix? i cant find any sort of 'how to' on this subject. the parts only 30$ but if i have to rip open my dash or electrocute myself im a little concerned
shelooga is offline
Old 07-11-2014, 05:12 PM
Bitter
Bitter's Avatar
Maybe a stupid question, but have you verified you have a full charge of Freon?
Bitter is offline
Old 07-11-2014, 05:41 PM
Nuke
Nuke's Avatar
Nuke is offline
Old 07-16-2014, 12:51 PM
shelooga
shelooga's Avatar
Originally Posted by Nuke
i havent only because i figured if the compressor wasnt switching on, it had to be related to that
shelooga is offline
Old 07-16-2014, 05:29 PM
Bitter
Bitter's Avatar
I'm not positive about Mustangs, but most AC units have a low pressure cutoff for the compressor.
Bitter is offline
Old 07-16-2014, 07:26 PM
jz78817
jz78817's Avatar
what Bitter said. there's a pressure switch in the A/C lines which will prevent the compressor from running if you lose the refrigerant.
jz78817 is offline
Old 07-23-2014, 12:59 PM
shelooga
shelooga's Avatar
as usual, everyone is right but me. threw in a can and it works, just not as icy as i remember.
thank you sirs!
shelooga is offline
Old 07-23-2014, 01:58 PM
Derf00
Gentleman's Relish
Derf00's Avatar
thank you sirs!
cos it's probably still low on refrigerant and it has a leak so the system never fully pressurizes when 'on'... get the leak fixed, problem solved.
Derf00 is offline
Old 07-23-2014, 07:01 PM
Bitter
Bitter's Avatar
I'm glad you got it sorted out without needlessly spending the money on a switch that would not have solved the problem. Those cans of refrigerant seem like the inexpensive way to go and I'm sure they are for some. As for me, I tried it and the needle was bouncing so wildly that I actually over pressurized it. In the long run, I paid the higher "one price fits all" to actually have a mechanic take refrigerant out. It now works fine, so in the long run it was worth the price.
Bitter is offline
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
07-05-2020 03:05 AM
UrS4
10-03-2015 06:23 AM
ChampInSD
10-02-2015 04:55 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: AC Control Switch
