be prepared to have to change the Fuel Injector Adapter, when I did mine several of them broke. Its a dealer only part that cost about $6 each part #9G512. You may get lucky and not have any break just fore warning of a possibility.
thanks for the replies folks.i had read somewhere about those manifolds cracking leaking etc.just getting some info.kinda looking before i leap lol.
The problem you are describing is on '95-98 Mustang GT cars.
The 4.0L mustangs have an issue with the plastic THERMOSTAT housing cracking. That's probably the problem you're talking about. Some simply replace it with a new plastic one from Ford. Other peeps have found and replaced it with an aluminum version or an upgraded plastic one.
" Better Than OEM. Re-engineered to address common failure points of the original, this Coolant Thermostat Housing is more than a replacement; it’s an upgrade that can withstands the extreme changes in temperature that frequently cause the stock factory housing to become brittle, crack and leak."
There are a few threads on this site about the problem if you search for it.
