Metal Thermostat Housing
Old 10-24-2014, 04:06 PM
tradosaurus
tradosaurus's Avatar
Default Metal Thermostat Housing
I bought a metal thermostat housing from someone on this forum and noticed that there are two holes for the temperature sending unit. Both holes are completely open.
Since I only have one temperature sensor how do I plug the other hole?
Thanks.
tradosaurus is offline
Old 10-25-2014, 06:39 AM
jz78817
jz78817's Avatar
pipe plug, with thread sealant.
jz78817 is offline
Old 10-25-2014, 09:08 AM
tradosaurus
If the hole was threaded I would agree with you.
Why the hell did they make a thermostat housing with two holes in it if it was for a Mustang?
Old 10-25-2014, 12:20 PM
artsvettes73
artsvettes73's Avatar
Should only be one hole. I'd contact who you purchased it from.
artsvettes73 is offline
Old 10-25-2014, 02:10 PM
tradosaurus
<<<@!1!@>>>
I bought it off a forum member who no longer has a mustang. I'm trying to get some info from him.
Has anyone who purchased a metal thermostat housing received one with two holes?
Or was the one I bought for another vehicle?
The Ford Ranger 4.0 L housing has two holes
http://www.ebay.com/itm/01-06-explorer-sport-track-and-Ranger-4-0-V6-Metal-Thermostat-Housing-/301319627126?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AFord%7CModel%3ARanger&hash=item46280ca176&vxp=mtr
Old 10-25-2014, 08:29 PM
Moderator
JimC's Avatar
While it has 2 holes - are they both open all the way? Even on the stock plastic one (which the metal one was fashioned after) there are 2 holes but they are not open.
JimC is offline
Old 10-25-2014, 08:58 PM
tradosaurus
If I can wiggle my finger through both holes from the inside would you consider the holes all the way through?
Old 10-26-2014, 12:39 PM
Bitter
Bitter's Avatar
Post a picture. It sounds like it's not meant for a S197.
Bitter is offline
Old 10-26-2014, 12:54 PM
conor1148
conor1148's Avatar
If I recall from my install (car is sold now), the temp sensor is not a screw in, so there are no threads. If i remember right it just pushes in and twists and it's done.
If you have two completely open holes, then you have the upper half portion from a ranger's thermostat housing. The mustang one, while it did have the spots in the mold where the second one would go, only has one hole for a sensor. So the mustang one pretty much looked like it had a second sensor spot, but the hole was never drilled out.
Don't quote me on this, but I'm pretty sure the two housings for the mustang and ranger/explorer are the exact same molds and they just leave one spot undrilled on the mustang one.
conor1148 is offline
Old 10-26-2014, 10:17 PM
tradosaurus
I contacted the vendor of the metal thermostat housing and I will be shipping the housing back in exchange for the one for the Mustang.
Quick Reply: Metal Thermostat Housing
