Slight oil leak top of valve covers. Tiny device
Old 10-28-2014, 07:19 PM
IvanRad
IvanRad's Avatar
Default Slight oil leak top of valve covers. Tiny device
Here are the pics any ideas on what this is im sure i just need an oring or a gasket or to tighten it up will wash my engine this weekend and dig deeper.
http://m.imgur.com/p4jKhwR
http://imgur.com/khxOSJF
IvanRad is offline
Old 10-29-2014, 11:39 AM
IvanRad
IvanRad's Avatar
Anyone?
IvanRad is offline
Old 10-30-2014, 04:16 PM
2005Redfire6
2005Redfire6's Avatar
May be wrong but I would guess that is possibly a cam shaft position sensor
2005Redfire6 is offline
Old 11-04-2014, 12:31 AM
tx_zstang
tx_zstang's Avatar
Eddie is right. That sensor is held on with a single bolt. Remove the bolt, pull it out.
There is an o-ring on the sensor, and that is likely leaking, if the leak is from there.
tx_zstang is offline
Old 11-10-2014, 06:50 PM
IvanRad
IvanRad's Avatar
That is where the leak is coming from . Do i just buy a new oring or should i just replace the sensor ? Is there 2?
IvanRad is offline
Old 01-07-2015, 02:33 PM
66and06stangs
66and06stangs's Avatar
I do not know, but will look on my 06 tonight to see if there is anything I can add. The way most parts are I'd say you are probably looking at a new sensor unless you feel like trying to find an o ring on your own...
66and06stangs is offline
Old 01-07-2015, 04:51 PM
tradosaurus
tradosaurus's Avatar
At RockAuto parts supplythe camshaft sensor is under $40. I didn't see a seal. I would take the sensor off and see if you could just use a o-ring from an autopart store.
tradosaurus is offline
Old 01-08-2015, 08:59 AM
66and06stangs
I looked at mine last night and it is not leaking. If it were leaking I'd be up to take it off and see what I could see, but with it sealed, i'm hesitant to pull it off. Sorry...
StalkerGT
09-25-2015 02:41 PM
bconboy
09-21-2015 12:52 PM
Pyrate Dave
09-10-2015 07:30 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Slight oil leak top of valve covers. Tiny device
