GT500 tranny swap or T5 rebuild?
Fellow stang modders,
I have a 4.0 and I am seriously looking into swapping/fixing my beat up T5 tranny this upcoming winter and I need some advice! Currently my tranny/clutch has 100k and is rough going into reverse, 1st, and sometimes second (especially when its running hot!) I'm unsure of whether just replacing the clutch would resolve my issues or if I am looking at a complete tranny rebuild.. I was seriously looking into the GT500 swap but as expected it looks very expensive. Eventually I'm looking at getting into the 400hp range and obviously I would like to have a reliable setup so I would appreciate some opinions from those that have the experience!
With your HP goals, get the 8.8" rear end because the 7.5 won't last and don't bother trying to build it up - it will cost you more than a swap.
You can upgrade the transmission but you need an adapter plate to make it work. The only one that I know of is built by member NicePony. (I think that is his screen name here). And yes, this time IvanRad is correct - if you change from the T5 to the GT500 transmission you will need a custom length driveshaft but since it is being built to your specs just have the ends set up to properly mate with the transmission end and whatever rear end you have (the 2005-10 GT and 2011+ Mustangs have different flanges so you have to know which year your rear end came from when you do the swap).
The key word I see here is eventually so I'd caution against spending money on something that might not make sense in the future. A built T-5 or trans swap might be the right move for you but I'm seeing you've already got 100K. So the question is by the time you ready for more power is it still going to make more sense. It may be cheaper to do a complete drive train swap, or maybe simply go with a used GT or newer 3.7.
As far the shifting issues with the T-5 I would suspect worn synchros. Has the fluid been changed regularly and are you using synthetic ATF? If you're over 30K between changes I would start with a fluid change, Mobile1 or Amsoil preferably and see how it goes.
I often change my fluids earlier than I should! I always do my oil change around 3-4k Mobil one and she's never burns a drop of oil! Its the only car I've had where I put in 5quarts and come out with 5quarts lol
