Heater fixed! Antifreeze leaking...
Sooooo, after getting into the car and the "heat" blew as hot as the ac I had one of my friends look at it and they said it could be a low antifreeze level. Checked it and of course it was close to empty. Filled er up and boom it fixed the heater. Oh I was so happy. Then the next day when I get to school I had noticed a substantial amount of smoke coming from under the hood. Popped it open and the cap on the antifreeze tank was gone and the fluid was all over the place. I could have sworn the cap was on but it obviously wasn't. So thus there was fluid all over the engine bay. Then I went to the nearest parts store and got a new cap and fluid filled it up and away I went. Got home and cleaned everything up with a rag and some water and thought the problem was solved. Then the next day while I was changing the oil I kept getting hit with drops of antifreeze. Then upon further investigation I noticed it was all over the place, in the engine and under the car. I then asked someone at class, auto tech class, what he thought and he said it could be the water pump. Right now I'm going through a jug of fluid every other day. This started yesterday and I feel like this is a problem that needs to be fixed soon. After watching ~$20 literally go up in smoke I have to get it fixed soon. Any input will be greatly appreciated.
Not the water pump. It is more likely the plastic thermostat housing. Look at that, it usually splits on the back side and blows under intake manifold into the valley.
Easy repair, just look for a write up on here, I think it is in a sticky. There is an aluminum replacement available now too.
You can probably see it just checking it - and it is often mistaken for a water pump problem because the fluid will seep that way. Look toward the back of the housing and under the intake manifold. Your description fits the housing issue.
Replacement is pretty easy (unless you have the Xcharger Xtreme like I had, because one bolt is trapped under that system). Basically disconnect the coolant lines, unplug the sensor, take out 3 bolts and lift straight up. Three bolts to remove the top housing, and transfer it over.
Yeah I got a better look at it today and all around the base of the housing there is antifreeze and it looks like the source of the leak. The hoses I could see looked fine to me. Also does anyone know if I need both upper and lower housing parts or one or the other. I cant see the lower housing so I cant tell if there is any damage there. Just wondering.
Unless you're really strapped for cash, you're not saving that much by doing only one. A set can be had off of eBay (and elsewhere) for $40-60 with new O rings. You'll already have it apart and the extra money is worth the peace of mind, in my opinion.
