Advice LSD differential
Hi all!
I wanted to install on my V6 2005 mustang the 3.73 Ford Racing gears.
they have advised me to install a lsd differential.
What differential do you recommend?
I've seen this, how does it look?
Auburn Gear HP Series 7.5in 28 Spline Mustang Limited Slip Differential 542023 (79-85 V8; 86-10 V6) - Free Shipping
Thanks!!
Thanks!!
It would be a lot better to just get a 8.8" rear with gears already installed and just swap the axle's. The new 8.8" is from FRPP (Ford racing) so it already has upgrades in it.
http://www.cjponyparts.com/ford-raci...FYhafgodUVIAug
Ford no longer makes a locking differential for the 7.5 anymore so they are scarce - very few aftermarket options. It will take some searching to find anything. Make sure whatever you get is for the 31 spline axles and not the 28
31 spline axle? I tought the 2005 v6 Was 28 spline axle :-/
if u wanna save $$$ get a used one(7.5 posi) from ebay. I found two for nearly $200. 8.8 Rear ends are the way to go but you need $1300 plus installation costs unless u do it yourself. And there are junk yards. In fact im going to call one right now
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
KingRando
10-02-2015 08:06 AM
