To replace struts or Not
Old 02-24-2015, 08:40 PM
Greg950
Greg950's Avatar
Default To replace struts or Not
Need some advice.
I bought my Daughter a 2006 Base coupe V6 two years ago which now has 95,000 miles . Ever since she's had it every time she goes over a speed bump she hears a thud noise in the front. It also does not have a smooth ride, you feel every little rough spot in the road.
I tested the struts by pushing up and down on the front corners of the car, the car goes right back to normal with no rocking up or down.
I am trying not to spend any money if I can help it, but If I were to replace the struts, probably using Monroe Quick struts since I do not want to mess with the springs would the noise disappear and give her a quieter smoother ride? What would you do as money is a major concern.
Thanks for the help
Greg
Greg950 is offline
Old 02-25-2015, 06:05 AM
66and06stangs
66and06stangs's Avatar
Search this forum a bit for struts. I recently read several when I had some thoughts about struts myself. My car is right at the 45K mileage range, and I decided I did not need new struts. There is some very good info here though, a forum search will answer your questions.
66and06stangs is offline
Old 02-26-2015, 05:53 AM
JJHoover
JJHoover's Avatar
has the car been lowered?
JJHoover is offline
5.0muscle
01-11-2016 01:17 PM
9550
10-26-2015 05:01 PM
GentleBen
09-11-2015 05:34 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: To replace struts or Not
