Oil Question
I suspect you're more concerned about the weight than the brand. 5W-40 is heavier than what is recommended. I believe the recommended weight is 5W-20. Will it hurt it? Probably not, but that's a risk I wouldn't take simply because it was cheap.
The track pack GTs come with 5w50 and have the same engine as non track packs. So 5w40 is not going to hurt anything.
The decision to use 5w20 from the factor was influenced by a slight gain in fuel economy, amongst other reasons. Oil is heavily discussed here and I encourage you to do some searching and form your own opinion on the facts at hand.
I'm with Goldenpony on this one. The OM calls for 5W-30 for the 4.0 and it's not a major change to use the next weight. But I, too, would be leary of it in cold weather, simply to be conservative.
