'06 MUSTANG - AIRBAG HELP, ALSO PATS HELP
Old 07-03-2015, 06:37 PM
AIRBORNE2323
AIRBORNE2323's Avatar
Default '06 MUSTANG - AIRBAG HELP, ALSO PATS HELP
Ok guys, need some serious help here. I bought a '06 with the 4.0 base about 2 months ago. I had to replace both airbags. I sent off the module to safetyrestore.com to get repaired. I'm still getting airbag code 42 for the front crash sensor. I have replaced the front sensor to no avail. I have checked the wiring from the sensor to the module, can't find any damage. The continuity check with my multimeter shows good wiring. The connection is clean between the sensor and the radiator frame area. I took it to the dealer today and they were absolutely no help. They suggested replacing the entire wiring harness for $3300. Ridiculous. Anything I'm missing? Also, the anti-theft engages sometimes for no reason. Sometimes, it'll start up the next time, sometimes it takes an hour. Who knows. Any help would be greatly appreciated.
AIRBORNE2323 is offline
Old 07-03-2015, 08:18 PM
Moderator
JimC's Avatar
Is all of that controlled by the smart junction box? Is the floor/carpet wet on the passenger side? The drains can plug up, and then water comes into the cabin right on the SJB (it is located in the kick panel on the driver side) so that can cause some issues with various electrical systems.
JimC is offline
Old 07-03-2015, 10:08 PM
AIRBORNE2323
The connection from the front crash sensor to the airbag module does not run through the SJB. It's a straight connection which is one reason why I can't figure out why it doesn't work.
I did just recently fix the water drainage issue. It was definitely leaving huge amounts of water in the floorboard. I just bought the car, so by the time I found the problem, the corrosion damage to the SJB had already been done. I cleaned as much as possible, but there's quite a bit of work to do yet. Maybe the anti theft system runs through it, not sure.
Old 07-03-2015, 11:46 PM
jz78817
jz78817's Avatar
if there was that much water in the interior, the restraints control module (RCM) might have been damaged.
jz78817 is offline
Old 07-04-2015, 12:04 AM
AIRBORNE2323
I thought it might be damaged also, but I recently sent it in for repair and programming. They assured me the airbag control module was working properly.
Old 07-06-2015, 08:08 AM
AIRBORNE2323
So the problems with my anti theft system has progressed. Looks like I need a new Smart Junction Box. Any further ideas with the front crash sensor??
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: '06 MUSTANG - AIRBAG HELP, ALSO PATS HELP
