Engine Icon Light on Dash Stays On ??
Old 09-05-2016, 01:30 PM
philipswanson
philipswanson's Avatar
Default Engine Icon Light on Dash Stays On ??
Not sure if the yellow engine icon on the dash is the check engine light but it stays on despite the OBD II scanner reading no codes. Even when I clear it with the scanner, that little icon shaped like a motor stays on. Is this the check engine light? Why would it be on with no codes in the system? The engine seems to be running fine.
Thanks, Phil Swanson
philipswanson is offline
Old 09-05-2016, 02:04 PM
Moderator
JimC's Avatar
Some codes you need the Ford tool to read I have found. Try stopping by an Auto Zone and see if they can pull up anything on their tool.
JimC is offline
Old 09-05-2016, 03:44 PM
philipswanson
Thanks but my tools are far superior to anything Auto Zone has or sells and their people are a bunch of no loads from what I've seen. Auto Zone here won't even check any more because they have been sued for faulty diagnosis on cars which has cost their customers big bucks.
Have any of you guys gotten false lights before with no codes?
Old 09-06-2016, 08:16 AM
proeagles
proeagles's Avatar
Take it to your local Ford dealer.
proeagles is offline
Old 09-06-2016, 10:32 AM
philipswanson
Guess I will have to talk to the Ford dealer but before I go to that expense, I was wondering if any of you guys had experienced the same issue and if so, how did you fix it?
Old 09-06-2016, 12:28 PM
Goldenpony
Goldenpony's Avatar
I second, I'd go to Ford and have it checked out
Goldenpony is offline
Old 09-06-2016, 12:33 PM
movielover40
movielover40's Avatar
You could be like my dad and put some black tape over it.
He drove his Cougar for years with it on.
movielover40 is offline
Old 09-20-2016, 10:51 AM
66and06stangs
66and06stangs's Avatar
I laughed at this one....
66and06stangs is offline
Old 09-20-2016, 02:57 PM
Derf00
Gentleman's Relish
Derf00's Avatar
This thread was missing some details. Problem was fixed in another thread:
https://mustangforums.com/forum/2005...-no-codes.html
Engine had been replaced. Turned out to be the Auto Trans harness for the solenoid pack was dirty/not seated correctly.
Derf00 is offline
MS75165
10-26-2021 07:18 AM
sharkred7
17
05-15-2016 01:49 AM
jgull1g
04-04-2016 02:41 PM
stwarrior23
03-15-2016 01:57 PM
98StANG4.6
04-30-2003 07:27 PM
Quick Reply: Engine Icon Light on Dash Stays On ??
