Terrible Oil Leak (Upper Engine)
Old 09-21-2016, 08:57 PM
philipswanson
philipswanson's Avatar
Default Terrible Oil Leak (Upper Engine)
This 2007 Mustang leaks oil like crazy from somewhere on the upper L/H side. I rebuilt the engine recently and it runs great, passed smog but leaks oil like crazy. It is pooling in the upper valley. We just replaced the L/H valve cover which was cracked but it didn't fix it. We installed a new Ford one. Leaks as bad as ever. Anybody have any ideas? It is my understanding that the intake manifold has no oil in it so I am at a total loss. Am I missing something? It's hard to see the source with all the crap in the way. It's definitely engine oil. Any ideas?
Thanks, Phil Swanson
philipswanson is offline
Old 09-22-2016, 02:05 PM
philipswanson
I am trying to figure out on the 4.0, what could be the source of an oil leak into the valley, other than the valve cover gaskets??? Any ideas???
Phil Swanson
Old 09-24-2016, 04:18 PM
philipswanson
I found the main oil leak, there may be others. I put floresant dye in the oil and viewed it at night with a UV purple light. Lit up beautifully and it turned out to be the L/H driver's side, chain tensioner. I didn't put in the thin soft metal seal. Put that in and torqued it to spec and it still leaks just as bad. What gives? Anybody else have trouble with leaks from the tensioner (s)?
Phil Swanson
my65coupe
09-23-2016 06:50 AM
FubarGrn
07-08-2016 11:28 AM
puttputtt
07-04-2016 04:57 PM
Frank Bullitt
07-01-2016 02:39 PM
torchred02
07-01-2016 09:38 AM
Quick Reply: Terrible Oil Leak (Upper Engine)
