Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-27-2006, 01:30 AM   #1
BlackMage
1998 Ford Mustang
My Garage
BlackMage's Avatar
Vehicle: 1996 Ford Mustang GTS
Send a message via AIM to BlackMage
Default Bolt-On Part testing on dyno, for all to read
Ok, im currently a student at the Universal Technical Institute in Chicago, IL. Im currently enrolled in a street legal performance class, where I have the chance to work on an 02 Mustang GT, 5 spd. The car has 45000 miles on it. The color is gunmetal, and is completely stock when i start.
Alright, Day 1, we tested the car with a 5-Gas machine, we are running a little lean but nothing that will hurt the stang. I have two exhaust leaks where the stock h-pipe connects to the mufflers, enough to hcange the O2 output on the 5-gas but opnce again, nothing going to hurt the stang. I checked all fluid levels, rear differential fluid, brake fluid, power steering fluid, engine oil, transmission fluid, and engine coolant. I also went through the car with a Modis scanner and made sure there were no codes in the system.
Once all completed i put the stang on the Dyno. We use a Dynojet system. We baselined the car at 221 Horsepower and 254 Ft/Lbs Torque. We did a second run to make sure it was accurate and came up with numbers of 218 Horsepower and 251 Ft/Lbs Torque. Ok accurate enough.
There are numerous mods i will be performing and testing on the Dyno within the next two weeks on the mustang. Some of them include as simple as changing an air filter, taking off the air box, or as big as NOS and also a Vortex supercharger. There will also be exhaust modifications, seen as how this is a street legal course, we will have a chance to add high flow cats and will be able to change out to different mufflers.
I will try to post as often as possible as I do these mods and run the stang on the dyno. I will post pictures of the Dyno pulls and we will see if changing an air filter, exhaust, or adding a power adder will make your PI Mustang any faster than it is.
Will
__________________
DRIVE A HYBRID MY MUSTANG NEEDS YOUR GAS
Fresh Paint!!!!!
MF Member #2679 of 109775
Install Guides by yours truly: Clutch cable, PI Intake, Mishimoto Fan, Color your FORD Emblem, Interior Carpet
BlackMage is offline   Reply With Quote
Old 04-27-2006, 02:06 AM   #2
SOHCtimes2
Default RE: Bolt-On Part testing on dyno, for all to read
I cant wait to hear more.
SOHCtimes2 is offline   Reply With Quote
Old 04-30-2006, 09:28 PM   #3
Acer2428
Armed Moderator
Acer2428's Avatar
Vehicle: F-250 7.3L Powerstroke
Ok guys, sorry i didnt get a dyno slip for this one, forgot my camera. but i wrote down the numbers and yes they are accurate.
For our first dyno test we installed a 75 mm BBK throttle body along with a BBK High Flow Plenum. BBK says it has posted up to a 15 HP and 20 ft/lbs gain when used together. Installation was relatively easy. All it takes is some basic hand tools and basic knowlegde of them. We pulled off the old plenum and thorttle body in about 30 min and had the new ones installed in about the same time. After this we took the car for a drive to make sure the car learned that we have modified the intake and gave it time to re calibrate the engine. Ford says to drive for up to 10 miles so we gave it about 15 miles. We pulled back in and started right up on our dyno run.
After three pulls on the dyno we discovered we had lost about 1 hp and about 3 ft/lbs of torque on average. After comparing the runs to the baseline tests we had done, we discovered we had gained a little more on the low end torque but it pretty much equaled out on the top end of our naturally aspirated engine.
After this test we have another Mustang GT 2003 we are able to use. This one has a Vortech Supercharger on it, a v-2 s-trim, pushing 8 psi. We will save the HP rating for this car later on in the tests. After installing the same setup of intake plenum and thorttle body onto this car, we saw much more dramatic increases in HP. BBK said they say up to 15 hp gained and 20 ft/lbs gained, well with this setup we saw a dramatic 18 hp gained and 21 ft/lbs on this forced induction mustang.
And once again sorry for not including the dyno sheets as i was not able to get them.
Will
__________________
Quote:
If god wanted you to hit your target on the first try, he wouldn't have invented the semi-automatic.
Acer2428 is offline   Reply With Quote
Old 09-29-2008, 03:49 PM   #4
Alias3800
man I wish I had that class here at my school!
Either way, it seems awesome.. I'll be keeping up with this too, very interested.
Rob
Alias3800 is offline   Reply With Quote
Old 09-29-2008, 03:51 PM   #5
Alias3800
I'm like.. 2 years late.
Damn
Old 09-29-2008, 05:33 PM   #6
defconfire
defconfire's Avatar
Vehicle: '99 Mustang GT
This is why I hate the search function......
__________________
Patriot Heads
CMS stage 1 Cams
Bolt-ons
Griggs Built Road Race Suspension
For Sale: - ::SOLD:: -
Current Ride: Showroom Stock 2002 Electron Blue Z06
-I wanted the LSX without the F-body attached-
defconfire is offline   Reply With Quote
Old 09-29-2008, 06:18 PM   #7
cliffyk
cliffyk's Avatar
Too bad, it would have been great to see some real, unbiased numbers. The TB/Plenum "gains" do not surprise me in the least, without a tune intake mods are good for nothing...
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 09-29-2008, 06:29 PM   #8
lizzyfan
Made Moderator
lizzyfan's Avatar
Vehicle: 98 GT Blumurder
Quote:
Damn
Yea you are!
__________________
Tuned by Matt at Performance Evolution
432 rwhp
426 tq
DD-2008 Mazda3 Zoom Zoom!
1996-Ranger (AKA "Barney") RIP 305K!
lizzyfan is offline   Reply With Quote
Old 09-29-2008, 07:46 PM   #9
avlon06
avlon06's Avatar
Vehicle: 2000 Mustang GT
some pretty good info, keep up the good work!
__________________
Exhaust clip
avlon06 is offline   Reply With Quote
Old 09-29-2008, 08:01 PM   #10
tbirdscwd
tbirdscwd's Avatar
Vehicle: 04 Black GT
I'm sure he will keep up the work on this two year old thread. Nice zombie though
__________________
FS: Eclipse AVN-5435 GPS navigation DVD/CD head unit, very nice $300 incl. shipping
WTT: My DD Anthracite Ford GT replicas for DD anthracite Bullitts
tbirdscwd is offline   Reply With Quote
03, 2001, 2005, 46, bolt, dfw, dyno, gt, mods, mustang, ons, power, s197, tests, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
