Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-09-2006, 09:02 PM   #1
1SLO85
1SLO85's Avatar
Default Dyno Expectations and Advice
This was written by 2000GT4.6....THANKS.
A couple helpful tips/questions to ask:
1. What brand and model of dyno was used? Different brands/models of dyno read quite a bit differently from each other. On average, the mobile/above ground dynos will read the highest (dyno dynamics etc), followed by the dynojets, and then the mustang dynos which read the lowest. For reference, my car is making 38x on a mustang dyno, but around 415-420 on a dynojet.
2. Are they using corrected or uncorrected numbers? In either case, ask what the other numbers were. I have seen corrected numbers be both high and low from uncorrected ones, as this is taking into account weather conditions. I place very little stock in corrected numbers if they vary much from uncorrected ones.
3. GET a BASELINE done on your car. It is much easier to swallow that the dyno is screwed up if you get a baseline on your car (no mods done) and it reads 250 WHP or something crazy. At least you know that the dyno is not accurate right off the bat. Most shops will let you do one or three dyno pulls without a/f for like 30 to 80 bucks, its well worth it. Another plus is that you get a TRUE feel for how much power you have added to the car.
4. Do NOT get pissed if everyone comes on and tells you your numbers are messed up. If everyone is telling you this, its not a consipracy, its just because YOUR NUMBERS ARE SCREWED UP. People are trying to help you, not to metion saving you embarassment from being called a ricer at your local car hangout.
5. There is NO such thing as a "factory freak". You are not going to get a car that makes any more than 5-10 WHP more than another person with the same mods, assuming you both have a good tune. This is not the 60's, and there arn't freak camshafts etc laying around the production floor just waiting to be accidentally installed. I should know, I worked in automotive for over 4 years. You are not going to make 20+ more WHP than another person with the same setup simply because you have a "super great tune" from "joe at supernatural motorsports". There are definatly bad tuners out there, but espcially when talking about a n/a boltons car, there simply is not that much difficulty in tuning the car.
6. ANY SHOP can at ANY TIME make a dyno read whatever they want. With a few clicks of the mouse I can have your stock 96 NPI car making 500 WHP. It really is that simple. There HAVE been quite a few shops known to dyno your car, add a few simple parts, and then crank up the dyno and give you false numbers to make themselves look good. If your getting 20 WHP out of that catback and 30 out of a CAI setup, its time to start looking for another shop. If they are shady on the dyno, what else are they shady about?
On to what to expect:
Your average stock 5 speed 99-04 GT will make around 225 to 230 WHP. The auto cars will on average read 10 to 15 WHP less, so figure around 210 to 220 WHP. ALL of the 99-04 cars (autos vs autos etc) are THE SAME. The differences in the engines were nothing more than ford saving money/refining the manufacuting process.
Your average 5 speed car with all the boltons, that is to say LTs, midpipe, catback, filter to throttle body aftermarket, (be it a RAI or CAI) throttle body, plenum, and underdrive pulleys, will make somewhere around 255 to 265 WHP, depending on tune, and around 300 FT/LBs. I have not personally seen ONE car over 265 WHP, but I would say that 270 WHP is believable with all the boltons and the stock gearing, as the stock gearing will read SLIGHTLY higher than a set of 3.73s/4.10s If you are making signfincantly more than this YOUR DYNO IS OFF, plain and simple.
Adding a set of cams to the above mentioned car will put it in the 280 to 290 WHP range, with a few of the more agressive camshaft profiles and great tunes making power in the low 290s. The more agressive cams will generally loose a bit of torque, but with the proper tune a stage 1 or even 2 should still make 295/300 ft/lbs.
Adding a set of ported heads will put you somewhere in the 310 WHP range, assuming you still have the factory shortblock.
If your car is significantly out of wack with any of these numbers, you are simply on a dyno that is reading high/low. The most important thing to realise is that THIS DOESN'T REALLY MATTER. Dynos are not ment to be tools for bragging/racing (although the mustang dynos do allow you to run a 1/4 mile on them, but I am extremely sceptical of the results). The ENTIRE purpose of a dyno is to show the difference between before and after your modifications, and to help tune the car. So long as a dyno is CONSITANT it doesn't really matter if it tells you 10 or 1000 WHP.
I dunno if it is so, but I almost feel this quailfys as a stickey? Not that anyone ever reads stickeys, but at least we can just point to the top of the forum and give em a link the next time a boltons only car comes in making 300+ WHP
__________________
1SLO85 is offline   Reply With Quote
Old 03-09-2007, 06:14 PM   #2
SwedishGT
Default RE: Dyno Expectations and Advice
this should most def. be a sticky... first thing I looked for when I joined!!
__________________
SwedishGT is offline   Reply With Quote
Old 03-09-2007, 06:19 PM   #3
ROB 98GT
"joe at supernatural motorsports". Damit he tuned my car !!
__________________
98 Mustang Gt - magnaflow catback, upr catted x-pipe, pi intake, k&n fipk, trick flow plenum, mac 75mm TB, diablo tune, frpp 4.10's, trans-go shift kit, b&m tranny cooler, built 4r70w, h&r sport springs, steeda rear sway bar
ROB 98GT is offline   Reply With Quote
Old 03-09-2007, 07:07 PM   #4
CAROLINAHAND74
cool thanks kinda wondered but no local shop
__________________
99 GT steeda pullies steeda shifter eibach lowering springs diablo tuner 373 gears deancecharger cai kingcobra clutch forged steel crank 13 inch brakes drilled and slotted
CAROLINAHAND74 is offline   Reply With Quote
Old 03-09-2007, 08:55 PM   #5
lizzyfan
Made Moderator
lizzyfan's Avatar
Vehicle: 98 GT Blumurder
Quote:
ORIGINAL: SwedishGT
it is!
__________________
Tuned by Matt at Performance Evolution
432 rwhp
426 tq
DD-2008 Mazda3 Zoom Zoom!
1996-Ranger (AKA "Barney") RIP 305K!
lizzyfan is offline   Reply With Quote
Old 03-09-2007, 09:09 PM   #6
DeltaV
Vehicle: 2003 Ford Mustang GT
Send a message via AIM to DeltaV
Def. a stickey!
__________________
Have a tax question? Call me, the local Mustang Forums CPA!
Cam Videos
http://www.youtube.com/watch?v=VhyPKhFkBks
http://www.youtube.com/watch?v=vv-JKjb3qfk
DeltaV is offline   Reply With Quote
Old 03-09-2007, 09:50 PM   #7
PWORLDSTANG
Code, sticky this now! Lol.
__________________
'04 Cobra
Too many mods to list..
Stage IV Port, etc.
473RWHP/467RWTQ (Old Numbers)
New Numbers Coming Soon
Tuned by Shaun @ Advanced Engine Development
PWORLDSTANG is offline   Reply With Quote
Old 03-09-2007, 10:05 PM   #8
mylongvictor
mylongvictor's Avatar
+1 on the sticky!
__________________
Procharger P-1SC 3 Core Intercooler
-477rwhp 460rwtq at 8psi (3.40 Pulley)
-8 Rib Pulley Conversion w/ 3.00 Pulley coming soon
-TKO 600 Swap
-Sanity on back order
(Old 3650 Tranny, Driveshaft, and PI heads.... For sale... PM me)
mylongvictor is offline   Reply With Quote
Old 09-21-2007, 10:46 AM   #9
03CentennialVert
What do you mean by LT's?
03CentennialVert is offline   Reply With Quote
Old 09-21-2007, 11:08 AM   #10
02STALKERGT
Vehicle: 02 GT
This was great to read as I am getting my car tuned tomorrow at DEZ. A/F ratio messed up since my MAF change.
Definately asticky!
__________________
02STALKERGT is offline   Reply With Quote
456, 80, 98, dyno, false, gt, lowest, made, mess, mustang, pulleys, pulls, readings, reads, test, underdrive, whp
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
