hows the ride on the street. Where im from the streets are just a big pot hole so i cant sacrifice ride quality
__________________
01 Mustang GT Vert 5-Speed
KB 9 PSI I/C! Big Tube Kit, FRPP 3.73, Full Bolt-On, Full Suspension, Built Axle, Built Driveline http://www.fquick.com/toplessgt01
I want springs that will help with weight transfer AND lower my car...so pretty much every lowering spring available is out, since they will negatively effect my launch...
Can fox body springs be used for daily drivers? And where can you buy them?
__________________
2003 Torch Red Mach 1 w/ bolt-ons For sale/Trade
http://www.cardomain.com/ride/2528597
300hp/320tq
Here's what will get it for you.......
Fox-body 4cyl springs (NAPA #270-3060) up front w/ Lakewood 90/10 struts
Fox-body V8 rear springs (cut to desired height) w/ Monroe Sensi-trac shocks
Airbag in RR spring
No front swaybar
UPR sub-frame connectors
Steeda 4600 Lower Control Arms
D&D adjustable uppers
Torque boxes welded
No quad shocks
Here's the drop, around 1 1/2"
__________________
SCT tuned by Greg @ Speedy Dyno
12.51 @ 108 w/ CMS stage II cams
11.35 @ 120 NX
Thanks for the kind words[8D] The rear springs were cut 1 1/2 turns with a grinder with a slitting wheel. I pulled them out 3 times and cut only 1/2 turn at a time to make sure I didn't over cut.
Yes the shock and struts are Fox length. The quad shocks are the small horizontal shocks on the read axle housing. They are easily removed by pulling the wheel and removing 2 bolts each. They should not be removed until you have at least aftermarket lower control arms
__________________
11.35 @ 120 NX
What is the benefit of removing them? And why after the LCA's? How would the foxbody springs compare to FRPP C-Springs (weight distribution wise)?
Removes dead weight. The LCA's will control wheel-hop. C-Springs give a similiar drop without the weight transfer....they suck at the track
__________________
11.35 @ 120 NX
