You are talking about the gasket that goes between the end of the exhaust manifolds/(or headers..if you have them) and the midpipe....that is the "collector" gasket
I have a Bassani Mid-pipe and cat-back on the way this Saturday that I am going to install over the weekend. Should I be worried about this gasket as well?
__________________
2002 White GT Convt.
Bassani X-Pipe, Bassani Cat-Back, Pro-5.0 Shifter, 3.73, JLT RAI, P.P Plenum/75 MM. Throttle Body
The driver's side midpipe to header does not use a gasket, the passengar's side does (this is the one you need). Your car comes with one stock from Ford, but when you install your midpipe go uy an OEM gasket from your Ford dealership as stated, it will run you like 9 bucks. The guy will print out a sheet that shows your whole exhaust systemjust to be sure lol..
__________________
[img]please respect the 500x250 size limit[/img]
04 DSG 'Vert
MRT Catted H
Borla Stingers
Bilstein Shocks/Struts
H&R Race Springs
MM Rear Lower Control Arms
MM CC Plates
Eibach Sway Bars
Mach 1 Brakes w/ Powerslot
DD Bullits
i just bought one for my car yesterday at ford, go to the dealership and buy it from them, they will have it and if they dont they will tell you wat dealers do that are close to you. just tell them the gasket between the manifold and midpipe not the manifold and head
