Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-08-2007, 04:49 PM   #11
03greyGT
03greyGT's Avatar
Vehicle: 2003 Mustang GT
Send a message via AIM to 03greyGT
Default RE: Cam suggestions
Im runnin stage 2s on stock heads and there fine. Im plannin on doin headwork down the road so thats why I got them. But there are quite a few people runnin a stage 2 cam with stock heads. Youll be fine.
__________________
03 GT, full bolt-ons, cammed, gears...
03greyGT is offline   Reply With Quote
Old 08-08-2007, 05:03 PM   #12
2002GTAUTOVERT
some of the stage 2's require work due to piston slap.. VT's cams dont... you can run stage 1 or 2 cams with stock heads but with stage 2's youll need a valve spring upgrade.. i was simply saying if you have any head work after you put those cams in.. you might consider a tune to take advantage of the better flow
__________________
478.46 whp 471.11 wtq.
"I'm honored to shake the hand of a brave Iraqi citizen who had his hand cut off by Saddam Hussein."
- Washington, D.C., May 25, 2004
George Bush
2002GTAUTOVERT is offline   Reply With Quote
Old 08-08-2007, 09:19 PM   #13
03greyGT
03greyGT's Avatar
I agree, but you have to get a tune anyways cause the computer wont be able to compensate as well as it does for a stage 1. So plan in getting a tune in order for your car to run if you go with stage 2s...as well as the spring upgrade. And it also recommends some sort of intake and exhaust upgrade which you have but you never mentioned gears. VT recommends atleast a 3.55 gear in order to compensate for the lack of low end. Im not sure how critical it is, but id look into gears anyways seeing how they really improve acceleration and get you into the powerband a lot quicker...
__________________
Old 08-08-2007, 11:13 PM   #14
01GT4.6
Moderator
2001 Ford Mustang
01GT4.6's Avatar
Vehicle: 2001 Mustang GT
Quote:
ORIGINAL: 2002GTAUTOVERT
I believe piston slap is the term used for when the cylinder is over bored and there is too much piston to wall clearance and the pistons slap inside the cylinder. What you are talking about is an issue with PTV (Piston To Valve)clearance, which is when the valve will hit the piston and put a 1/2 moon cut into the piston.
01GT4.6 is offline   Reply With Quote
Old 08-10-2007, 10:48 AM   #15
stangracer04
Quote:
ORIGINAL: 03greyGT
I have 3.73 gears andthinking about gettinga trick flow intake maniflold.
__________________
02 GT
BBK LT headers
BBK O/R H-Pipe
2 Chamber Flows dumped at axle
MGW Shifter
3.73 Gears
K&N Cold Air
75MM Throttle Body
Lowered 2 Inches
Nitto 555R's
stangracer04 is offline   Reply With Quote
Old 08-10-2007, 02:16 PM   #16
boss281
Vehicle: 03 mustang GT
what is the deal with the trick flow manifold? is it out already? decent power gains?
__________________
5SPD, GT
boss281 is offline   Reply With Quote
Old 08-11-2007, 04:27 PM   #17
stangracer04
I dont have the manifold yet it said you could get around 20 hp from it. But yea it had two versions around 800 dollars for 99-04 gt, Ithink i sawit on summitt if not just try and google it.Im just thinking i may need one.
__________________
02 GT
BBK LT headers
BBK O/R H-Pipe
MGW Shifter
3.73 Gears
K&N Cold Air
75MM Throttle Body
Lowered 2 Inches
Nitto 555R's
Old 08-11-2007, 04:41 PM   #18
jersey98gt
will that thing fit 96-98 gts
__________________
98 Gt ragtop
Bassani CB, Bassani Catted X
BBK CAI, Cobra/Brembo brake kit, , KYB front shocks
http://www.cardomain.com/ride/2257514/
jersey98gt is offline   Reply With Quote
Old 08-11-2007, 05:32 PM   #19
stangracer04
Yea they make one for that year too its 799 on summitt racing.
__________________
02 GT
BBK LT headers
BBK O/R H-Pipe
MGW Shifter
3.73 Gears
K&N Cold Air
75MM Throttle Body
Lowered 2 Inches
Nitto 555R's
Old 08-11-2007, 06:18 PM   #20
2000GT4.6
I had stage 2 cams in with just boltons, no other engine work, and while I did loose a few ft/lbs down low, I picked up 20 WHP peak and 30 WHP at redline... a pretty decent gain.
I would lag behind a bit on a stock cams car... and then walk away once I got into the powerband. They also have a very nice lope but don't idle so badly you can't handle it.
__________________
2000GT4.6 is offline   Reply With Quote
cams, modular, mustangs, na, powerhouse
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
