New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-08-2007, 12:19 PM   #1
stangracer04
Default Cam suggestions
Im wanting to install a cam on my 02 mustang gt, ive got 75mm tb, cold air, bbk lt headers, bbk h-pipe, and 2 chamber flows dumped at the axle. I want something that will sound incredible along with the performance, but i drive my car everyday so nothing too extreme. What do you guys recommend? Thanks Mike
__________________
02 GT
BBK LT headers
BBK O/R H-Pipe
2 Chamber Flows dumped at axle
MGW Shifter
3.73 Gears
K&N Cold Air
75MM Throttle Body
Lowered 2 Inches
Nitto 555R's
stangracer04 is offline   Reply With Quote
Old 08-08-2007, 12:29 PM   #2
2002GTAUTOVERT
Default RE: Cam suggestions
sound incredible... VT Stage 2 but you need new springs and head work to take full advantage of them
Sound nice... VT Stage 1'sdont NEED new springs but you definetly should get them. need head work to take advantage
__________________
478.46 whp 471.11 wtq.
"I'm honored to shake the hand of a brave Iraqi citizen who had his hand cut off by Saddam Hussein."
- Washington, D.C., May 25, 2004
George Bush
2002GTAUTOVERT is offline   Reply With Quote
Old 08-08-2007, 12:36 PM   #3
nathansee3
Vehicle: 2000 Ford Mustang GT
+1 on VT stage 1's. you can check for some videos of them on youtube. They have a nice lope and with your dumps would sound killer.
__________________
00' Black GT 2V
BBK Plenum
BBK 75 mm Throtle Body
MGW Short Throw
BBK Long Tube Headers
BBK o/r H
Magnaflow Magnapack Stainless Catback
Spec Stage 3 Clutch
Spec Billet Alluminum Flywheel
H&R SS Lowering Springs
KYB Adjustables
nathansee3 is offline   Reply With Quote
Old 08-08-2007, 01:11 PM   #4
wgdt21
I've seen some members say they didn't get the lope they wanted from the stage 1's. The stage 2's have good lope, but you do need head work to actually gain much from them.
__________________
03' GT, SLP o/r X, SLP LM II catback, JLT RAI, Eibach sportlines, MM C/C's, Zoom stg. 2 clutch, dress up.
http://www.cardomain.com/ride/2451849
wgdt21 is offline   Reply With Quote
Old 08-08-2007, 01:28 PM   #5
01GT4.6
Moderator
2001 Ford Mustang
01GT4.6's Avatar
Vehicle: 2001 Mustang GT
I suggest getting a set of custom cams from Modular Powerhouse (MPH). You can call Tim and let him know your mods and plans with the car and he can get you a set of custom grind Comp Cams for the same price as off the shelf cams.
01GT4.6 is offline   Reply With Quote
Old 08-08-2007, 01:45 PM   #6
stangracer04
I have heard the stage 2 on a car similar to mine it sounded good. Am I going to lose performance in the bottom end by getting this, and what about an intake do I need a new one?
__________________
02 GT
BBK LT headers
BBK O/R H-Pipe
MGW Shifter
3.73 Gears
K&N Cold Air
75MM Throttle Body
Lowered 2 Inches
Nitto 555R's
Old 08-08-2007, 02:13 PM   #7
2002GTAUTOVERT
an intake is good if you plan on passing the redline with higher spinning forged internals... other than that its not necessary yet. stage 2's are aggressive and you should have head work with those.
__________________
George Bush
Old 08-08-2007, 02:25 PM   #8
Shelbyville
Vehicle: 2002 Mustang GT
What head work are you referring to? P&P? If so, is it really necessary or just a bonus to add some HP?
__________________
2002 GT
Steeda cat'd X
JLT RAI
FFRP 4.10 gears
H & R Sport Springs
Steeda Caster/Camber plates
BBK Headers
Steeda UDP's
Accufab 70mm TB and Plenum
Topiko struts, Bilstein rear shocks
Tune by XXTuning
Shelbyville is offline   Reply With Quote
Old 08-08-2007, 02:54 PM   #9
stangracer04
so your saying that I could put the stage 2 in like it is and do head work later
__________________
02 GT
BBK LT headers
BBK O/R H-Pipe
MGW Shifter
3.73 Gears
K&N Cold Air
75MM Throttle Body
Lowered 2 Inches
Nitto 555R's
Old 08-08-2007, 03:14 PM   #10
Shelbyville
It was my question to 2002GTAutovert. Wanted to know what head work meant? Port and polish I suspect but just want to make sure. I am thinking of cams myself but not for a while. Need $$$$. Just wanted to know how much work was involved.
__________________
2002 GT
Steeda cat'd X
JLT RAI
FFRP 4.10 gears
H & R Sport Springs
BBK Headers
Steeda UDP's
Tune by XXTuning
cams, modular, mustangs, na, powerhouse
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
