New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-14-2007, 11:28 AM   #21
2000GTFOOL
Vehicle: 2000 Mustang GT
Default RE: HOW TO: Fix the 4.6L GT Ticking noise...
Quote:
ORIGINAL: 6mustang6
Damn man. My car is just turning 80,000 on a 2000 model. If my engine started doing that, i would be really really really pissed.
Trust me mine had 78k when the problem started.. I WAS LIVID... The kicker is LOTS AND LOTS of people seem to have the same problem.. ALL on the passenger side.... Can you say faulty parts...... Some people had it happen during the break-in period... I really wish Ford would stand behind thier products, are they turning into GM or what??
__________________
2000 Mustang GT- K&N intake, Forza Exhaust, re-gear, 17x9 Bullitts, K-sport 2" lowering springs, grill delete, clear/smoke headlights, Mach 1 chin spoiler, Alpine CD w/eq/mach 460, 03 gt hood scoop, UPR billet camber adjustment plates.
2000GTFOOL is offline   Reply With Quote
Old 11-14-2007, 11:52 AM   #22
6mustang6
Send a message via AIM to 6mustang6 Send a message via Yahoo to 6mustang6
i know man. That really sucks. I just pray i have a good set. but knowing my luck ill be having to re-read your write-up one day.
__________________
2000 GT Mustang Convertible
1966 Mustang coupe- all original, soon to be 4v swap.
1967 Mustang Conv- Freshly restored.
6mustang6 is offline   Reply With Quote
Old 11-14-2007, 07:56 PM   #23
2000GTFOOL
Ok.. Here is the deal, FORDmerged the part numbers for the timing chain guideson the 99-04 Mustang GT's with the 4.6L SOHC. Unfortunately they are using the replacements from the 99-EARLY 2000 GT guides as the part number. That part number will NOT bolt up to the LATE 2000-2004 GT's.. This poses a problem to people like me who have engines/cars that were built late in the production run. Ford was UNABLE to get me the guides I needed as they have mistakenly assumed all the 4.6L used the same guides and mounting points, which they don't. They made a note of my complaint and hopefully they will re-visit the part #'s and application.
I found the parts that fit the late 2000-2004 models at AUTOZONE.
According to the Autozone Part #
716436
716437 These are the VDP part #'s.
Hope this helps anyone else doing this service. It has been apain in the ass that the parts I ordered didn't fit the car.....
__________________
Old 11-15-2007, 01:25 AM   #24
Nitti00GT
I had pics of my front cover when it was off but I can't find them now. A good way to tell is just count the number of bolts on your valve covers. That will tell you if you have a windsor or romeo. I think the romeos have the same number for both sides and I think it's 11 and the windsors have a different number of bolts per side. Also the water pump pullies are different. The windsors are pushed out in the center where the romeos are in.
__________________
2000 Mustang GT- forged J&E pistons, 283cid block, ported heads, Comp cams, JLT CAI, 75mm TB, ported plenum, Mac LTs & o/r H, Super 40s, MSD COP, SCT tune, SPEC clutch, 10.3:1 CR.
-Next- gears, shifter
1994 Lightning (sold)
Nitti00GT is offline   Reply With Quote
Old 11-15-2007, 09:30 AM   #25
MrChubs1
The pink scooter and the Haynes manual scare me the most. I assume the scooter is your daughter's or sister's, but the book? [:-]
__________________
2007 Dodge Charger SRT-8 (CAI, Magnaflow Catback)
2001 Mustang GT (CAI, muffs, UDPs, 3.90s)
1972 Chevy C20 Pickup, 402, 700R4
1970 Dodge Challenger, 440, 4sp (my toy) -- 12.67 @ 117.76 MPH....poor driver and suspension
All American garage,
MrChubs1 is offline   Reply With Quote
Old 11-15-2007, 09:36 AM   #26
Mark99GT
Quote:
ORIGINAL: 2000GTFOOL
716436
Did you actually try to bolt them up? Im using all of the timing equipment from my 99 on an 03 shortblock with no issues at all.
__________________
Mark99GT is offline   Reply With Quote
Old 11-15-2007, 02:15 PM   #27
99BlackPonyGT
aka Negative Nancy
Vehicle: 1999 Mustang GT
Send a message via AIM to 99BlackPonyGT
ford dealership wanted 1600 to do this lol... "15 hours of labor, and $400 for tensioners, guides, and gaskets"
oh and the OP should definately get a contributor tag for this
99BlackPonyGT is offline   Reply With Quote
Old 11-15-2007, 02:29 PM   #28
Derf00
Quote:
ORIGINAL: MrChubs1
The scooter was his mode of transportation during the work and his inspiration to get it done quickly/correctly the first time!
Goodwrite up though. I wonder if the V6 models suffer from the same thing as a lot of them have ticking (not slapping like that though). Since the chains are vertical, I wonder if this scenario would even be possible.
Derf00 is offline   Reply With Quote
Old 11-15-2007, 02:32 PM   #29
Mark99GT
Hey, did you get this up and running yet? Just an FYI here, I just noticed this... You didn't mention holding the camshafts in place while you removed the tensioners and gudes in your original post. The camshafts will rotate, causing the gears to "jump teeth" in the chains when you remove the tensioners. It happens quickly and if you're not paying attention you won't even notice it. Visually everything will look fine, but your camshaft timing will be off which could be disasterous. If the camshafts rotate you need to re-time them.
Oh, and if you have metal and plastic pieces floating around in your oil there's a good chance they're stuck in the pick up tube screen as well, which can restirict oil flow. I know when my rod bearings went, my pick up tube screen was a mess with shavings (and it had a huge chunk of my radiator cap stuck in it, don't ask, I don't know). Unfortunately you have to drop the entire oil pan to look at it...
__________________
Old 11-15-2007, 02:39 PM   #30
adam_ferguson
the reason the guides did not fit is because 99-00 models have a windsor block , whereas the later models have romeo blocks.
__________________
i don't have enough characters for my list ..... :-(
LS What?
adam_ferguson is offline   Reply With Quote
46, 50, 99, bad, chain, cobra, mustang, noise, oil, pump, squeaking, tensioners, ticking, timing, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
