Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-15-2007, 02:47 PM   #31
Mark99GT
Default RE: HOW TO: Fix the 4.6L GT Ticking noise...
Quote:
ORIGINAL: adam_ferguson
the reason the guides did not fit is because 99-00 models have a windsor block , whereas the later models have romeo blocks.
Yeah I know that, butmy timing equipment fit just fine. I know there are small differences in the blocks, but for the most part all of the parts are interchangeable.
EDIT: 2000GTFOOL, I think the part number ford was using was for the pre 99 motors. In 01 ford changedthe romeo motors tothe windsor style allplastic guides, found in the 99-mid 01 motors. Which explains why my stuff fit...
__________________
Mark99GT is offline   Reply With Quote
Old 11-15-2007, 05:13 PM   #32
califas_1987
Different blocks different part numbers?!?! Doesn't that defeat the purpose of these being MODULAR engines?!?! WTF Ford?!?!
__________________
Mods: All FreeMods I can Find, and some Photoshoped Dark Charcoal Bullits
Quote:
Originally Posted by 99GTvert View Post
Run a 100 shot of STFU.
califas_1987 is offline   Reply With Quote
Old 11-15-2007, 07:38 PM   #33
2000GTFOOL
Vehicle: 2000 Mustang GT
Wait.. So do the 99-00 have the plastic guides or the metal guides with the sleeves??
Here are what my parts look like. The guy at ford told me the "romeo" blocks are the cobra blocks and the "windsor" blocks are the GT.. He claims some mustangs got the Romeo blocks with GT heads ect.. I think they have thier heads on backwards...
Whatever, I have the parts I need now...... Thank goodness....
[IMG]local://upfiles/57395/7EEABE26F97648F2AF3D7648323EE3D9.jpg[/IMG]
__________________
2000 Mustang GT- K&N intake, Forza Exhaust, re-gear, 17x9 Bullitts, K-sport 2" lowering springs, grill delete, clear/smoke headlights, Mach 1 chin spoiler, Alpine CD w/eq/mach 460, 03 gt hood scoop, UPR billet camber adjustment plates.
2000GTFOOL is offline   Reply With Quote
Old 11-15-2007, 08:03 PM   #34
2000GTFOOL
As far as the tensioners/locking the cams go.... My chains have almost no tensionon them at all.. The cams haven't moved at all yet.......I figured that if I was careful they wouldn't move..lol
I did the timing belt service on my Lexus LS400 and the cams were a much bigger pain in the ass... Huh..
__________________
Old 11-15-2007, 10:17 PM   #35
Mark99GT
Quote:
ORIGINAL: 2000GTFOOL
Thats risky man, I did the same thing and ended up tearing back into my engine because the timing was off. You've got it apart still right? If so, pull the valve covers off and set the timing properly. Its easy to do and might take an extra hour. Beats bending a valve or punching one through a piston. And my guides looked exactly like your original broken ones (just not broken).
__________________
Old 11-15-2007, 10:18 PM   #36
99gtstang
good write up-
does it only do it when cold?
Mine knocks when cold, After the vehicle warms up it goes away!
__________________
UDP
O/R X W/Flowmasters
75MM TB/PLENUM
K&N CAI
Diablosport Tuner
3.73's
B&M shifter
Rear C/A's
Ford C Springs
Sub Frames
it's really slow!
99gtstang is offline   Reply With Quote
Old 11-15-2007, 10:51 PM   #37
2000GTFOOL
Quote:
ORIGINAL: 99gtstang
good write up-
That's how mine started.. then it progressed..
__________________
Old 11-17-2007, 04:59 AM   #38
abe9090
[:@][:@]I think that my 01 Auto GT is starting to get this issue.. it has 98,8500 and change on it, completely stock. I wouldnt describe mine as ticking ; but more of a squeaking noise when Im driving it. It doesnt seem to do this noise when the car is still.
abe9090 is offline   Reply With Quote
Old 11-17-2007, 09:17 AM   #39
99BlackPonyGT
aka Negative Nancy
Vehicle: 1999 Mustang GT
Send a message via AIM to 99BlackPonyGT
that doesnt sound like this issue at all....
99BlackPonyGT is offline   Reply With Quote
Old 11-17-2007, 09:24 AM   #40
2000GTFOOL
I agree. That would more likely be rear end, wheel bearing, ujoint... If it only happens when you are moving.... UNLESS it's only under load... But still I don't think that it is your chain..
__________________
46, 50, 99, bad, chain, cobra, mustang, noise, oil, pump, squeaking, tensioners, ticking, timing, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
