Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-08-2008, 03:51 PM   #61
pete1665
Vehicle: 2000 GT
Default RE: HOW TO: Fix the 4.6L GT Ticking noise...
Quote:
ORIGINAL: 2000GTFOOL
The guides I ordered for the 2000GT do not fit at all.. The guides that will fit my car are from a 2002-2004. I need to figure out how to reference #'s to see if my engine has been swapped out... Has anyone with a 1999-2001GT have pictures of thier engine with the front covers off?? I am going to attach the schematics later.... This is crazy that OEM parts wouldn't bolt up.. I just wonder what the deal is with my car.. It is worlds faster then all the other same gen GT's I have driven.... WTF...
I just got done replacing the tensioners/guides in my 2000GT and had the same part number problem.Theparts store that i go to ('Parts City' outside of chicago)had one part number listed for all '99-'04 GTs. And all of theparts stores around here seem to sell 'Cloyes' brand timing components. So after researching at http://www.cloyes.comi found cloyes lists the tensioners/guides that I need as being listed for a 2002gt. The following part#'s are what fit my 2000GT...
Right Hand Tensioner arm--
http://www.cloyes.com/Aftermarket/Pa...S/Default.aspx
Left Hand Tensioner arm--
Right Chain Guide--
Left Chain Guide--
the TENSIONERS themselves were listed correctely at the parts store under a 2000GT, but here are the cloyes part#'s anyway..
Right Tensioner--
Left Tensioner--
Hopefully this helps people in the future. I ended up having my local parts store special order these part #'s for me and everything went smoothly from there.
Just to note, i have an early 2000gt with the windsor block, so im not sure if late '00 gt's and newer would have the same issues.
pete1665 is offline   Reply With Quote
Old 01-08-2008, 06:02 PM   #62
pete1665
Vehicle: 2000 GT
P.S. -- If you already have the front timing cover pulled off, you do not need to remove the oil pan to replace the oil pump. There are two small bolts that connect the sump to the pump, but if you have small enough fingers and an 8mm wrench(if i remember correcly.. maybe 10mm) you can get it out like i did. Theres really no reason to remove the pan.
Just make sure you have one of those magnet stick things because you WILL drop the bolts a few times when trying to screw them back in.
Old 02-01-2008, 10:53 AM   #63
hockeyskate101
I just bought a 98 Gt about a month ago and the guy had warned me about a ticking that had been going for the last 20000 miles on it approx and so like an idiot i bought it umm i signed up for the forums just for this reason haha apparently im not alone
people tell me its a lifter one person said it was an intake valve getting stuck but it only makes the noise really between 2 and 3500 rpms and i just wanna know if finding out whats wrong with it is worth it or can i just let it go on even though id rather fix it
if it is a lifter im gonna have to get new cams too right cuz theyre gonna be all worn out egg shaped what have you
__________________
remote start, flip out touchscreen, 12" subs..i got all of it for like 100$ total insurance kills me cant do performance till new job
hockeyskate101 is offline   Reply With Quote
Old 02-05-2008, 01:30 PM   #64
hpwrestler220
hpwrestler220's Avatar
Vehicle: 2001
mine is doing the same stuff as your saying
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
3) Get rear decklid shaved and painted DONE
4) Get fog lights sprayed with black/clear mix
5) Get lower valence re-sprayed
So far, i'm 1/5....
hpwrestler220 is offline   Reply With Quote
Old 02-11-2008, 08:40 PM   #65
brock_07
Vehicle: 2004 Mustang GT
man thats an amazin write up...but im not about to try it
__________________
2004 GT 5spd, flow 40's, CAI, 75mm t/b plenum, motive 3.90's, diablosport predator
2008 Civic Si Sedan
brock_07 is offline   Reply With Quote
Old 02-12-2008, 08:15 AM   #66
BolognaPony
Does anyone know if this is related to the Windsors or if it affects the Romeos as well?
I have a late production 01 and its only got 49k on it, but its starting to make a ticking sound from,best i can tell, drivers side.
I can only hear it well when the clutch is just grabbing and the motor vibratesa bit. I can hear it VERY faintly if i let the car sit in neutral and stick my head in the engine bay.
__________________
01 GT - FRPP 4.10, FRPP catback, UPR X, tri-ax, focus pump, NX Plate Kit @ 100
7.9@86 on 28x9 ET Drags/cold bottle/spark blowout :-/
BolognaPony is offline   Reply With Quote
Old 02-17-2008, 10:53 PM   #67
buwaleed
my cars is making that same ticking sound! it's just bothering me a lot! thanks for the info, great post
buwaleed is offline   Reply With Quote
Old 02-21-2008, 01:06 PM   #68
maireeka
Is this a sound that happens throughout the rpms or something that only happens for a split second if you blip the throttle a bit?
__________________
Bone Stock 1999 Mustang GT
maireeka is offline   Reply With Quote
Old 02-27-2008, 12:19 AM   #69
QuarterMileMaster
You guys that are saying you have this problem all seem to have 2000s and UP. I have a 1998 Cobra, with only 50K on the clock TOTAL, and about 2500 on the engine after being rebuilt. It's been stroked too... before i bought it.When I bought it, it had a bad rod bearing. I fixed it, and it runs good... but it makes that sound. Anyone know if this was a problem that only affected certain years or what??
QuarterMileMaster is offline   Reply With Quote
Old 02-27-2008, 12:11 PM   #70
micheal0484
2008 Pontiac G8
Vehicle: 2008 Pontiac G8 GT
Send a message via Yahoo to micheal0484
I have a 98 gt and my tensioners were bad... So I believe it covers the 4.6 era
__________________
micheal0484 is offline   Reply With Quote
46, 50, 99, bad, chain, cobra, mustang, noise, oil, pump, squeaking, tensioners, ticking, timing, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
