Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-15-2008, 07:33 PM   #81
P71Vic
P71Vic's Avatar
Vehicle: 2004,Crown Vic
Would that problem also cause a chatter when the engine starts?
__________________
Dual Flowmaster Super 44's
Rear Cat. Delet Exhaust Vid:
http://www.youtube.com/watch?v=VOYrFsy6enI
Exhaust Video:
http://www.youtube.com/watch?v=f-H6SmV5JAc&feature=user
P71Vic is offline   Reply With Quote
Old 10-27-2008, 12:07 PM   #82
2000GTFOOL
Vehicle: 2000 Mustang GT
Yes it would.
__________________
2000 Mustang GT- K&N intake, Forza Exhaust, re-gear, 17x9 Bullitts, K-sport 2" lowering springs, grill delete, clear/smoke headlights, Mach 1 chin spoiler, Alpine CD w/eq/mach 460, 03 gt hood scoop, UPR billet camber adjustment plates.
2000GTFOOL is offline   Reply With Quote
Old 11-01-2008, 07:21 PM   #83
Alaric GT
Unhappy Damn it.
I might have the ticking problem but I'm not sure. There's definitely a ticking sound coming from the passenger side but it only does it when I accelerate. If I put it in neutral and gas it there's no sound. If the car's just idling I can't hear it either. So all you mechanically inclined good folks, do I have the dreaded ticking problem or something else? Thanks in advance.
Alaric GT is offline   Reply With Quote
Old 11-02-2008, 12:59 PM   #84
2000GTFOOL
Quote:
Yikes.. So you'rs does it under load.... Mine was doing that too, but it did at idle too...
__________________
Old 11-04-2008, 07:29 PM   #85
crider4_6
crider4_6's Avatar
Vehicle: 2000,Ford,mustang GT convert
Cool mine tooooo
i done mine in about 2.5 hours and a 30 pack of keystone and my dad as my supervisor lol
109k miles
__________________
car cant be posted here due to not enought post's
perfosinal products plenum and tb 70mm plenum polished inside and out ,sct dyno tuned,242@5400rpm grenitelli coil packs ,24lbs inj
crider4_6 is offline   Reply With Quote
Old 11-09-2008, 02:06 AM   #86
PonyBoy2000
PonyBoy2000's Avatar
Default On Ford Rebuilds Too?
I bought my 2000 Mustang GT in Jan. of '06. By Dec. of '06 I had to replace engine with new rebuild from dealer (thank God for warrenties). I think I spun a bearing, not sure, mechanic didn't say. All that was said was that engine was no good.
Any way, the question is was this problem resolved on the newer rebuilds?
__________________
Alex Garcia
2000 Mustang GT 4.6 Bone Stock
1972 Buick Skylark Gran Sport
PonyBoy2000 is offline   Reply With Quote
Old 12-15-2008, 10:05 PM   #87
Colbert
Vehicle: 2002 Ford Mustang GT
Well, I just recently purchased a 2002 Mustang GT. I noticed today that it had a ticking noise coming from the passenger side of the engine. I searched online and it brought me to this thread. Luckily, it's still under warranty since I bought from a dealership. But at least now I will know what I'm talking about when I take the car in.
Colbert is offline   Reply With Quote
Old 12-15-2008, 10:12 PM   #88
0mustangGT2
Vehicle: ford mustang gt 2002
Send a message via AIM to 0mustangGT2
the reason for this is because all the 4.6 l up to 2002 werent threaded deep enough for the spark plug to sit in wen its in corectly they only sit in a thread and a half there hasnt been away to prevent it that i have found out on it its happened to several of my buddies gts
0mustangGT2 is offline   Reply With Quote
Old 07-06-2009, 01:14 AM   #89
al02gt
1959 Volkswagen Beetle
Vehicle: 02 4.6 GT
I have an 02 GT that ticks at idle.
It blew the #4 plug and I paid for FOrd to replace it. I replaced lots of parts and even pulled the heads off and replaced the valves/springs/keepers/bolts, etc.
I put the engine together and it still ticks. You can only hear it at idle, and it takes about 45 seconds for the tick to start if the car is cold.
Also takes it about 10 seconds to start after the cars comes off a rev back to idle.
I did a leak down on the insert and it was the same as the others so I put it back on the car.
So I'm thinking this is either an exhaust leak or oiling. I always ran royal purple 20/50 in the car before the plug blew and it didn't make the ticking noise so I'm wondering if oil has something to do with this?
I didn't see any visual wear on engine internals when I had it apart. I wished I would have replaced the piston wrist pins and bearings when I had the heads off.
But for now, the car has to be driven to work everyday.
al02gt is offline   Reply With Quote
46, 50, 99, bad, chain, cobra, mustang, noise, oil, pump, squeaking, tensioners, ticking, timing, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
