Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-20-2008, 06:24 PM   #1
kylebgt
Default Changing a belt on a GT??
How hard is it to change a belt on a pi 4.6L?? I am planning on installing a gatorback as soon as it warms up outside. Anyone have any experiance doing it? How long does it take?
__________________
My rides:
2000 Mustang gt 5spd & 1997 Jeep Wrangler TJ 5spd
Both modded
kylebgt is offline   Reply With Quote
Old 01-20-2008, 06:34 PM   #2
96GT226410
CSMG Moderator
Default RE: Changing a belt on a GT??
Very easy. It should take about 5 minutes. Good choice on the belt.
__________________
96GT226410 is offline   Reply With Quote
Old 01-20-2008, 07:46 PM   #3
Shawn02GT
you just need a good length 3/8" ratchet to stick down on the idler pulley to relieve the tension. then remove the old and install the new belt, be sure to route the new belt exactly the same.
__________________
'02 Mustang GT, V2SQ and full bolt-ons - SOLD
'06 Subaru Legacy Spec.B - AWD & BOOST!
Shawn02GT is offline   Reply With Quote
Old 01-20-2008, 08:05 PM   #4
99BlackPonyGT
aka Negative Nancy
Vehicle: 1999 Mustang GT
Send a message via AIM to 99BlackPonyGT
theres a metal plate that restricts how far you can release tension, i had to remove that plate when i put a belt on my car because i couldnt relieve the tension far enough to slip the belt on
99BlackPonyGT is offline   Reply With Quote
Old 01-20-2008, 08:06 PM   #5
99GTvert
6th Gear Member's Member
99GTvert's Avatar
Vehicle: 1
It shouldn't be hard, but take your time. If you had the car on beforehand, be careful where you touch (might be hot, obviously).
I also gotted a Gatorback [8D]
__________________
1999 Mustang GT
11.6 @ 166 mph, LOL corrected
Quote:
Originally Posted by redass02gt View Post
SHE SAID CUM!!! OMG!!!!!
BOOBOOJABABAJABABABAJABA!!!
99GTvert is offline   Reply With Quote
Old 01-23-2008, 11:34 AM   #6
BlackMage
1995 Ford Mustang
My Garage
BlackMage's Avatar
Vehicle: 95 GTS, 96 GTS
Send a message via AIM to BlackMage
i had that stupid plate on my 98 gt too, not sure what it is for really, but should take 5-10 min as long as u know how the belt is routed and dont put it on wrong
__________________
DRIVE A HYBRID MY MUSTANG NEEDS YOUR GAS
Fresh Paint!!!!!
MF Member #2679 of 109775
Install Guides by yours truly: Clutch cable, PI Intake, Mishimoto Fan, Color your FORD Emblem, Interior Carpet
BlackMage is offline   Reply With Quote
Old 01-23-2008, 12:00 PM   #7
72MachOne99GT
1999 Ford Mustang
72MachOne99GT's Avatar
Vehicle: 1999 Ford Mustang GT
Send a message via AIM to 72MachOne99GT Send a message via Yahoo to 72MachOne99GT
That plate was apparently on some of the older 4.6's..
wheni replaced my tensioner, *the whole thing because it was seperating* it was actually causing that plate to be grinded away at by the pulley that was off line.
so i bought a new tensionder, and the hole for the wratchet doesnt even line up with the hole in the plate..
stupid ford..
__________________
'99 GT-5sp.
4.10's, O/R H, catback, MT's
13.6@100 1.8 60'
72MachOne99GT is offline   Reply With Quote
Old 01-23-2008, 02:42 PM   #8
racer02GTstang
Send a message via AIM to racer02GTstang
i have the factory belt on my car as of right now....
__________________
2002 GT ragtop 5-spd
HP stage 2 twin turbo kit
forged shortblock from MMR
VT stage 3 blower cams
stage 3 ported heads w/ oversized valves
built TKO500
P-51
+ alot more
693rwhp 608 toque w/ a slipping clutch and 18psi. on pump gas
racer02GTstang is offline   Reply With Quote
Old 01-23-2008, 09:23 PM   #9
fruhdaddy
5 mins and a beer...anymore then there is a problem
__________________
It has enough to surprise you....
fruhdaddy is offline   Reply With Quote
2002, 46l, belt, ford, mustang, release, tension, v8
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
