also if doing the pi swap, do heads from a windsor fit fit the romeo?
may be a stupid question but i have no idea about this subject
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
1996 Mustang GT. Full bolt on. momo short throw shifter, Racing seats, rear seat delete, FR500's. BBK 190 lph fuel pump
PI CAM AND INTAKE SWAP COMING!
ENGINE IDENTIFICATION [/u] ENGINE BUILD CODE LABEL The engine build code label on the RH cam cover, as follows: PASSENGER CAR[*] 6G 804 AA or AB - Romeo 4.6L 2V engine[*] 6G 808 AA or AB - Romeo 4.6L 2V engine with oil cooler[*] 6G 866 AA or AB - Romeo 4.6L 2V engine Natural Gas Vehicle (NGV)[*] 6G 926 AA - Windsor 4.6L 2V engine [/ul]
yes, different valve covers needed,
Romeo and Windsor are 2 diff designs. Romeo has separate bolts and grommets and a normal looking rubber gasket. The Windsor covers have grommets that attach to the bolts and they also have a diff gasket that wraps around each bolt. Cant mix and match the two.[/align]
__________________
Tuned by Matt at Performance Evolution
432 rwhp
426 tq
Yes, 96-98 is romeo and I think 99-mid 01 is windsor, then last 01-04 is romeo. Either way a windsor style head will work on a romeo block. The differences are that the windsor have 13/14 bolt valve covers and have bigger bolt holes that the timing case cover bolts to. They also have bolt on cam gears.
__________________
98Gt with pro 5.0shifter, 3.73's Pi swap and stage 2 CompCams, BBK Lt's, catless H pipe, Flows. Procharged 8psi
Romeos have bolt on cam gears. Windsors are pressed on.
windsors will fit but it will need some new bolts and valve covers and maybe a couple of other little things. If you can try and get a romeo PI head to make things go a bit smoother.
__________________
When you turn your car on, does it return the favor?
CAI, O/R x-pipe, Magnaflow catback, Diablo sport tuner, 3.73, king cobra clutch and lowered.
NOS
__________________
Romeo Blocks have 11 bolt valve covers, Windsor Blocks have 13 bolt valve covers. I have a 2002 GT with a vin X Romeo engine.
