Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-27-2005, 08:05 PM   #1
98stngfrk
Send a message via Yahoo to 98stngfrk
Default 4.6 to 5.4 swap ????
Well I have just aquired a 2001 5.4 from a wrecked Expidetion. The engine only has 40,XXX miles on it so I am thinking about takeing the heads off haveing them ported and polished, adding a set of cams, and then seeing if I can install this into my mustang. If I am not mistaking they will bolt right up using the stock transmission and motor mounts. I also know they use the same computer so it seems like it could be a simple swap. Any of you guys know anything about this, or anyone who has done it. Or just any articles or websites that have info on it?
98stngfrk is offline   Reply With Quote
Old 04-27-2005, 08:07 PM   #2
1SLO85
1SLO85's Avatar
Default RE: 4.6 to 5.4 swap ????
I looked into doing a 5.4 swap with ported/polished Navigator heads. After research, I determined it wasn't worth the time or money for the small gains the 5.4 would give over the 4.6. Just my 2 pesos.
__________________
1SLO85 is offline   Reply With Quote
Old 04-27-2005, 09:27 PM   #3
David_K
so you have ultimate bragging rights of a 5.4
__________________
David_K is offline   Reply With Quote
Old 04-27-2005, 09:34 PM   #4
099gt
go for it my friend who has a 98 cobra put a 5.4 engine in his car and it runs great and sounds great...he hasnt had any problems and he probly has about 5k with the new motor
__________________
99 Mustang GT
BBK long tube headers
BBK off road h pipe
BBK 70mm tb
Flow Master 40 series
3.73 gears
steeda tri ax
k&n air filter
subframes connectors
diablo
099gt is offline   Reply With Quote
Old 04-27-2005, 10:05 PM   #5
racer02GTstang
Send a message via AIM to racer02GTstang
i think it would be great to have a 5.4 in the car. bet it would run great if it was fully built.
__________________
2002 GT ragtop 5-spd
HP stage 2 twin turbo kit
forged shortblock from MMR
VT stage 3 blower cams
stage 3 ported heads w/ oversized valves
built TKO500
P-51
+ alot more
693rwhp 608 toque w/ a slipping clutch and 18psi. on pump gas
racer02GTstang is offline   Reply With Quote
Old 04-27-2005, 10:17 PM   #6
PI Pumped 98
I was going to do the same thing but only 5.4 dohc because the 2v just isnt worth it. You going to be adding alot more weight and minimal power. Im pretty sure the cooling system might be diff and i know you need difff brake booster to fit the heads in and i think the intake manifolds are completely differnt. There is an article on it in the new mmff. The reason i didnt do it was because i didnt want to go through the trouble of chaning the computer and cooling system for dohc and its jus too expensive for the gains.
__________________
98 GT 5spd "STONEMONK"
PI ported heads w/ 3 angle valve job , Custom CAI, Off road X-pipe, B&M short throw, Comp Cams 262ah, King cobra clutch, Mac TA, 3.73 Nitto Dr, lng tbs, Aluminum block w/ forged pistons and rods.
PI Pumped 98 is offline   Reply With Quote
Old 04-28-2005, 07:51 AM   #7
Sicx13
Send a message via Yahoo to Sicx13
i would actually like to see someone go thru with the swap and show some proof of the result. i dont know the specs of the 5.4 but im willing to bet it has alot more torque.
and someone made the comment about wieght, dosent the 4.6 and 5.4 share the same block.
i want to see how having those extra cubic inches responds to bolt on mods.
__________________
I hate to advocate drugs, alcohol, violence, or insanity to anyone, but theyve always worked for me.
Sicx13 is offline   Reply With Quote
Old 04-28-2005, 02:39 PM   #8
98stngfrk
I know that the intake would probably be the hardest part, yet I am almost positive that the computers are the exact same. I also don't think it woulb be that much of a weight difference. Also either way its gonna be better even bone stock than my pre PI gt. I could also do one of those stroker kits for the 5.4, just think a ported,polished, stroked out 5.4 in a mustang sounds awesome to me, I just don't know if I would ever be able to go with forced induction if I do go through with it.
Old 04-29-2005, 02:34 AM   #9
V8M2000
sounds pretty stud to me
__________________
2000 GT
Diablo Chip
Cat Back Straight pipe
Cold Air
SVT 17x9s
More to come
V8M2000 is offline   Reply With Quote
Old 04-29-2005, 04:28 PM   #10
Sicx13
where did you get the info that the computers are the same? i find that hard to beleive. i know that they are almost identical but they are of diferent displacements and would have a diferent powerband and different fuel and spark requirements. i think it could work but would be rough until you do some tuning.
on a side note whats the redline on the 5.4?
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
