Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-16-2008, 04:25 PM   #1
cbest1223
Vehicle: 2004 mustang mach 1
Default NEED HELP WITH CODES!
I have a post in the mach1 section but I bought a scanner and one of the codes it gave me is not in the manual. I got the codes p0300 (misfire) and the code p0316 and I do not know what that one is. Can anyone help.
cbest1223 is offline   Reply With Quote
Old 11-16-2008, 04:36 PM   #2
Brute03
Brute03's Avatar
Vehicle: 2003 Mustang GT
i know p0300 is a multiple misfire code and it's usually accompanied by a code for a speciific cylinder, are you the other code wasn't p0306?
__________________
2003 True Blue GT 5spd
-UPR x-pipe
-Flowmaster cat back
-Cobra Brakes
-Sniper tuned
Home-made mil's
Brute03 is offline   Reply With Quote
Old 11-16-2008, 04:45 PM   #3
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
Vehicle: 01 Lightning
p0300 is random misfire, and p0316 is misfire on startup
__________________
RESIDENT FORD TECH
`01 Lightning ----- FOR SALE http://mustangforums.com/forum/other...-for-sale.html
Stiegemeier stage 4 blower. LFP ported intake, Accufab TB, #6 pulley, 60# injectors, MAFia, Art Carr converter, JLP intake + traction bars, Magnaflow catback, AFCO h/e, LC1/XD16, SCT tuned by Matt @ Performance Evolution 448hp/508tq
WhiteFoxGT is offline   Reply With Quote
Old 11-16-2008, 04:46 PM   #4
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
Do the car feel like its missing under load?
__________________
RESIDENT FORD TECH
Old 11-16-2008, 09:36 PM   #5
cbest1223
when you are just cruising is when it misses. if you get on it the car runs great. idle you can hear the miss but not realy feel it. if you run about 55 in 4 or 5 gear the car will buck and jump. If you give more gas the miss goes away. any suggestions on where to start is greatly app.
Old 11-16-2008, 10:11 PM   #6
cbest1223
my codes are p0420 catalyst system bank 1, p0430 same bank2 ,p0300 misfire,p0316, misfire start up,po442 evaporative emission leak small,
Old 11-16-2008, 11:17 PM   #7
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
Quote:
420 and 430???
Does the car have the factory H pipe??? You got bad cats dude. Unbolt the h-pipe at the collectors, leave the h on, but with like a 1 inch gap and see if it runs any better.
__________________
RESIDENT FORD TECH
Old 11-16-2008, 11:19 PM   #8
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
As for the evap code, check the filler neck + filler neck seal. Its either that or one of the EVAP lines..or a bad vapor management valve
__________________
RESIDENT FORD TECH
Old 11-17-2008, 09:49 AM   #9
Brute03
Brute03's Avatar
Quote:
+1 check your fuel cap too
i'm guessing he has an o/r mid pipe
__________________
-UPR x-pipe
-Cobra Brakes
-Sniper tuned
Home-made mil's
2003, control, emission, evap, leak, mach, misfire, mustang, p0306, po442, system
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
