Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-07-2008, 11:16 PM   #1
aimhigh10
Vehicle: 1997 Mustang Cobra
Default Tick..tick..tick
I know, another tick..tick thread. I did a search on the "Ticking" problems but couldn't pinpoint what the problem may be. It sounds like if you take an ink pen and tap it on a table like your playing drums.
My 97 cobra is ticking on the Drivers side. You can hear it mostly under the car but also with the hood up. It does't get louder with acceleration but does get faster. I took it to an exhaust place and couldn't find any leaks. Does a header leak have a ticking sound? The guys used a stethascope and could hear it mostly from the cylinder 7 pipe on the long tubes. Could there be a leak there or something in the bottom part of the engine thats making the ticking.
Its not the spark plugs or wires arking off anything because I just replaced them all due to a cylinder 8 misfire code.
It sound to me like a fuel injector making the tick. I can hear it under the car and slightly out of the rear exhaust. I used a long screwdriver and put it up to the drivers side injectors and can hear the same tick when I put it up to my ear. Put the screwdriver up to the valve cover and heard nothing but smoothness.
Has anyone experienced the same problem or know what it may be. I can't stand the ticking noise. Like I said, I used the search tool regarding this but need some up to date advice. Thanks everyone
__________________
1997 Black Mustang Cobra-38K miles
BBK LT Headers, 87mm MAF, 62MM TB, Underdrive pulleys, MAC off-road H-pipe w/flow tubes, Flowmasters, Aluminum Driveshaft, Full length Subframe connectors, Billet upper and lower control arms, 3.73 gears, Pro 5.0 shifter, Koni adjustable shocks/struts, Ebach lowering springs, 17x10.5 rear w/315's and 17x9 w/245's, Fuel pressure and Air/fuel guages
aimhigh10 is offline   Reply With Quote
Old 12-08-2008, 12:14 AM   #2
jvog
Vehicle: 2002 Mustang GT
headers do tick when they are leaking. just because you replaced the plugs doesnt mean it wouldnt cause a tick. If they werent torqued properly one of them may be ticking.
__________________
2002 GT 5-Speed
V1 S-trim: 369 rwhp/361 rwtq
jvog is offline   Reply With Quote
Old 12-08-2008, 12:36 AM   #3
Donnie's GTS
Donnie's GTS's Avatar
Vehicle: 01 Ford Mustang Bullitt
sounds like a sticking exhaust valve if its not a leak on cylinder 7.
Donnie's GTS is offline   Reply With Quote
Old 12-08-2008, 12:40 AM   #4
67fire
Vehicle: '97 #240, Saleen Speedster and '69 Mustang Sportroof
Default Tick...Tick...Tick
I also, was thinking exhaust valve.
Valve or valve seat?
Eric
67fire is offline   Reply With Quote
Old 12-08-2008, 01:16 AM   #5
Chubstang
Chubstang's Avatar
Vehicle: 2002 GT
Send a message via AIM to Chubstang
You can rule out the the injectors by unplugging them one at a time. If the tick stops when you pull the power from 7, then you know that's what it is.
__________________
02 GT 5 spd.
-JLT RAI, MRT Catted H, SLP LM1.5 CB, MGW STS, C Springs,
Tokico HP's, MM FLSFC's
Chubstang is offline   Reply With Quote
Old 12-08-2008, 04:16 AM   #6
ezking
1997 Ford Mustang
ezking's Avatar
Vehicle: 1997 Mustang GT
Before I did the PI swap I had the same problem, and it was a spark plug.
Go see how tight all of your spark plugs are, mine had backed one out and was making the same exact sound, also if I drove the car very long at all the shift boot would heat up, from the leaking gases.
This can destroy your heads pretty fast. But just for me, go check to see if any of your spark plugs are finger tight.
ezking is offline   Reply With Quote
Old 12-08-2008, 09:09 AM   #7
aimhigh10
So as far as the injectors, I'm suppose to unhook the power one injector at a time while the car is on to see if the tick stops. Will that harm the car in any way? Throw a code?
As far as the exhaust valve ticking, where is that located on the engine. I'm guessing its where the headers come out. How can I test to see if it is indeed the exhaust valve. Like I said, I can't hear any tick from the valve cover while doing the screwdriver trick.
Its not the spark plugs, I tightened them plenty enough. Besides, it started ticking as soon as I started the car after the plug change. They all were very tight.
Where do I go from here???
__________________
Old 12-08-2008, 12:56 PM   #8
jvog
That's the problem. You need to torque them to spec using a torque wrench. Overtightening can cause problems
__________________
2002 GT 5-Speed
Old 12-08-2008, 01:08 PM   #9
Chubstang
Chubstang's Avatar
Vehicle: 2002 GT
Quote:
Nope, it will not harm it in any way and any code that is thrown will go away once it is plugged back in.
__________________
02 GT 5 spd.
Old 12-08-2008, 01:15 PM   #10
Chubstang
Chubstang's Avatar
Vehicle: 2002 GT
If it started right after you changed the plugs I would guess they have something to do with it. One of the plugs might not be seated correctly. I would pull the plugs back out, inspect them, make sure they have the metal gasket, make sure there isn't anything down in the holes that would cause it to not seat all the way. Do this when the motor is cold especially since it sounds like you overtightened them if they are "very tight".
__________________
02 GT 5 spd.
99, chain, cobra, crush, diesel, making, mustang, ngk, plugs, tick, timing, tr55, washer
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
