Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-11-2009, 10:24 PM   #11
Jazzer The Cat
Wheels/Tires Section Moderator
2002 Ford Mustang
Jazzer The Cat's Avatar
Vehicle: '02 s281 #0014
^ boy, I cannot say
Contact Bruce at Moderndriveline and he can say for sure.
Jazzer
Jazzer The Cat is offline   Reply With Quote
Old 02-12-2009, 04:45 PM   #12
SVTeeshirt
Vehicle: 1996 Mustang Cobra
ok thanks ya.
__________________
Fastest Closet on MustangForums.
I bought a goldfish, named it after my ex-girlfriend, and let it die. It's really the little things in life.
SVTeeshirt is offline   Reply With Quote
Old 03-28-2009, 05:59 AM   #13
2000AZ5.0GT
2000 Ford Mustang
Vehicle: 2000 Ford Mustang GT
The Viper Spec is Awesome. I'm at close to 12k on mine, and it gets me near 30mpg on the highway. That .50 final gear is AMAZING.
But good write up man
__________________
Quote:
Originally Posted by Rdot9 View Post
i could go for a nice can of cock rite now actually...
2000AZ5.0GT is offline   Reply With Quote
Old 03-30-2009, 12:10 AM   #14
Stevecooper
Yep, I love mine too
To add something else, I have a similar clutch to the one griggs wanted to sell to the OP. The whole thing with flywheel weighs less than 15lbs. This is a great way to reduce rotating mass.
__________________
2001 Bullitt
281CI Blue Printed Engine (Teksid, CP's, Manley Billit, Cobra Crank,) Foxlake Ported SVO heads, PI CAM's, kooks LT's, 2.3L Allen Twin Screw Blower, 63lb, SCT2800 MAF, Mcloed 8" Twin disk, Viper T-56, Griggs GR40 With Watt Link. SSR GT3's... and more.
535HP, 530TQ 12PSI .
11.77 128.5MPH (Times need some work )
5.4 Block 6L Stroker, 2V heads, Truck Intake. Sup now!
Stevecooper is offline   Reply With Quote
Old 05-11-2009, 11:24 PM   #15
dirtygirl [thats the cars name]
dirtygirl [thats the cars name]'s Avatar
Vehicle: 02 ford mustang gt
hey so im new here and with swaps but my question besides what you showed in your right up will the t56 swap right in i mean with bell housing bolts all that as in if i go to a junk yard get a t56 out of a cobra will it swap right in?! thanks man!
dirtygirl [thats the cars name] is offline   Reply With Quote
Old 05-12-2009, 08:20 AM   #16
Jazzer The Cat
2002 Ford Mustang
^ With all the issues addressed in my post, an '03~'04 Cobra T-56 will fit in just as mine did.
I recommend you read ALL the info on gear ratios, as this is the fundamental difference between the T-45/T-5/T-3650 transmissions. There are some additional ratios that are nearly exactly the same as the above, but just add a .8 gear between your current 4th and 5th gears (assuming you have a manual now). You can also get what is commonly known as the "Viper Spec" gears that have a final drive of .5 for good mileage on the highways.
Jazzer
Old 05-12-2009, 02:51 PM   #17
so the transmission you went with is the cobra spec t56 ?
Old 05-12-2009, 08:36 PM   #18
Jazzer The Cat
2002 Ford Mustang
^ not sure what gear ratios are in the Cobra
I went with the #1260, so ALL gears were indistinguishable from my T-3560 except the following. Approx. 30% taller 1st gear and .8 gear directly inbetween the 1/1 4th gear and the .68 5th gear.
This gave me a nice cruising gear for 50~60 MPH and completely eliminated the HUGE gap between 4th and 5th I had in my T-3650 Saleen and the T-5 I had in my previous '85 GT. This was a pretty expensive mod and would NOT have done it had it not been for the failing bearings I had.
Jazzer
Old 05-13-2009, 03:20 AM   #19
i hear what you mean but my gt has the 3650 i bought the car used at 70000 which was not bad and its in great shape but i put a steeda tri ax shifter and theres a lot of unsettling noises coming threw i do realize the factory shifter blocked alot of the noises but my old 84 gt had twice the miles and it was not nearly as bad it makes me think my bearings are getting weak i have actually had people say my car sounded like it had a turbo from the high pitch sound it makes while under a full launch first to second, i can also feel the vibration in the stick as well as the grinding shifts into second if the rpms and the shift delay are not right. i have to tell my friends its the syncros i know your thinking i cant shift but come on first to second is pretty easy and i have the clutch in all the way so im pretty sure the syncros are all but shot in second. do you know if the 3650 is a weak trans or if the failures are caused by excessive abuse my old t 5 fox seemed a lot more durable especialy after two years of hard driving to include power shifting?
Old 05-13-2009, 07:57 AM   #20
Jazzer The Cat
2002 Ford Mustang
I don't know much about the strength of the T-3650, but several I know have swapped it for a built T-45. If you are really interested, I can put you in touch with a guy that knows a LOT about this particular swap.
My particular trans had a noisy bearing I believed to be on the input shaft. It was ultimately diagnosed by my tuner during a dyno run. I had always heard the noise, but did not notice it until after all of my suspension work. I thought noise was normal and just introduced by torque-arm. It was not really bad, but saw the need to eventually replace/repair it as I did NOT want to get stuck out on the road somewhere. The T-56 was the correct answer for me and absolutely LOVE it
I do not know if the T-5 is a tougher trans, but any trans will eventually fail if one drives hard.
Jazzer
3650, 50l, 56, 95, clutch, cobra, fork, lockout, mustang, parts, reverse, swap, switch, t56, tr3650, transmission, works
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
