have you popped the hood yet im sure there are some bolts there im just going on memory hear from my car i think you need like an allen wrench to get the bolts off.
you unscrew the turn signals (one screw on each) first and they pop out with some work. then you remove the retaining clip on the upper plug of the headlight ( you will need to replace the clip when installing new headlights) . you then disconnect the headlight bulb, and pop out the headlights (there are 3-4 plugs that pop out, there are no other bolts as i remember). the headlight is in there real good so you have to give it a good tug. i broke my drivers side getting it out . you then do the reverse for installation, just remember to realign the beam. i did one at a time so i could use the stock one to align the new one. goodluck, its a half hour job if everything pops out good.
__________________
96' GT: 01 s281e motor vortech s trim aftercooled
88' Lx convertible
96' hyundai elantra
three plugs, no bolts might take a good push to pop the new ones in
__________________
1996 Mustang GT Convertible
ZEX 100 Shot, Zex Purge
2 1/2" Full Exhaust
Eibach Pro Kit,Tokico Blue Shocks and Struts
Subframe Connectors
King Cobra Clutch
Under-Drive Pulleys
Ford Racing Strut Tower Brace
