Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-29-2009, 11:51 PM   #21
S197winstang
S197winstang's Avatar
Vehicle: 2006 Mustang GT
Default check this out found it on the WEB
California's Laws Regarding Modified Exhaust:
A Perspective
It has come to the attention of Bob's Muffler that some California police officers are issuing summonses to California drivers who have aftermarket exhausts on their vehicles. Bob's Muffler feels this unfairly targets the people who chose to purchase our products for legal use on the streets and public highways of California. Bob's Muffler wants to examine the actual law and the areas it covers. We wish to educate our customers.
CA. V.C. 27151 No person shall modify the exhaust system of a motor vehicle in a manner which will amplify or increase the noise emitted by the motor of such vehicle so that the vehicle is not in compliance with the provisions of Section 27150 or exceeds the noise limits established for the type of vehicle in Article 2.5(commencing with Section 27200) of this chapter. No person shall operate a motor vehicle with an exhaust system so modified.
This shows that there are other characteristics that the exhaust system must conform to truly show a violation. This also shows that other vehicle codes must be considered when in violation of this vehicle code.
CA. V.C. 27150 (a) Every motor vehicle subject to registration shall be equipped with an adequate muffler in constant operation and properly maintained to prevent any excessive or unusual noise, and no muffler or exhaust system shall be equipped with a cutout, bypass, or similar device.
(b) Except as provided in Division 16.5 (commencing with Section 38000) with respect to off-highway motor vehicles subject to identification, every passenger vehicle operated off the highways shall at all times be equipped with an adequate muffler in constant operation and proper maintained so as to meet the requirements of Article 2.5 (commencing with Section 27200), and no muffler or exhaust system shall be equipped with a cutout, bypass, or similar device. (c) The provision of subdivision (b) shall not be applicable to passenger vehicles being operated off the highways in an organized racing or competitive event conducted under the auspices of a recognized sanctioning body or by permit issued by the local governmental authority having jurisdiction.
Part (a) states that the muffler must suppress any excessive or unusual noise. This refers to part (b) which states that the muffler must meet the requirements of Article 2.5, which refers to noise levels. Part (a) and (b) also refer to a cut-away, bypass or similar device commonly known as a "dump."
CA.V.C. 27200 (a) The Department of Motor Vehicles shall not register on a dealer's report of sale a new motor vehicle, except an off-highway motor vehicle subject to identification as provided in Division 16.5 (commencing with Section 38000), Which produces a maximum noise exceeding the applicable noise limit at a distance of 50 feet from the centerline of travel under test procedures established by the Department of Highway Patrol.
(b) The Department of Motor Vehicles may accept a dealer's certificate as proof of compliance with this article. (c) Test procedures for compliance with this article shall be established by the Department of the California Highway Patrol, taking into consideration the testing procedures of the Society of Automotive Engineers.
Part (c) of this section says that the California Highway Patrol shall set the testing standards in the for of California Code of Regulation, Title 13, Article 9, Section 1036 as denoted in letter from the Department of California Highway Patrol file 60.A9190.A9181.062.9610186.
CCR 1036 Passenger Cars and Light Trucks and Buses
Exhaust systems for motor vehicles, other than motorcycles, gross vehicle weight rating of less than 6,000 LB (2,722 kg) shall comply with the specified noise limits when tested in accordance with the following specifications:
(a) Measuring Site. The vehicle under test shall be positioned either on outdoor pavement or on a shop floor ( but not over a hoist or pit) in a location where the exhaust outlets are near an open shop door. No sound-reflecting surface other than the pavement and the vehicle being measured shall be within 10 ft (3.0m) of any part of the vehicle.
The testing is done in an environment in which there is minimal sound contamination. Please note that there is nothing stating highways or other public roads as being an exception to this criterion.
(b) Microphone Location. The microphone for the sound level meter shall be at the same height as the center of the exhaust outlet. The microphone shall be no closer to the pavement than 8 in. (203mm) when the exhaust outlet is lower than this height. The microphone shall be positioned with its longitudinal axis parallel to the ground, 20 inches plus or minus 1 inch (508mm plus or minus 24mm) from the nearest edge of the exhaust outlet, and 45 degrees plus or minus 10 degrees from the axis of the outlet. For exhaust outlets located under the vehicle body, the microphone shall be located at the specified angle and at least 8 in., (203mm) from the nearest part of the vehicle. For exhaust outlets that make an angle of 45 degree or less with the longitudinal axis of the vehicle, the microphone shall be outboard of the exhaust axis. For exhaust outlet angles of more than 45 degrees, the microphone shall be on the side of the exhaust axis to the rear of the vehicle.
This denotes where the sound measuring device is relatively close to the exhaust outlet. Notice that it does not make any references to provisions for sound level testing done from distances greater than 21 inches. <
(c) Engine Operation. The engine shall be at a normal running temperature with the transmission in neutral. System sound level measurements conducted for certification by exhaust manufacturers shall be made at an average steady-state engine speed of three-quarters of maximum rpm. Sound level measurements conducted by licensed muffler certification stations shall be made at an average steady-state engine speed of 3,000 rpm for vehicles manufactured before 1972 for which the station does not have a maximum rpm data.
Please notice that the engine is supposed to be running and the law has no provisions for parked vehicles. Note that the certification can be done by the manufacturer of the exhaust system. There is no requirement that the manufacturer sound test each individual vehicle. Re: "licensed muffler certification stations," the letter from the California Highway Patrol file Number 60.A9190.A9181.062.9610186 states in the third paragraph that these facilities were canceled in 1978 due to budgetary cut-backs.
(d) Exhaust Sound Level Measurement. The recorded exhaust system sound level of a stationary vehicle shall be the highest reading obtained during the test, disregarding unrelated peaks due to extraneous ambient noise. When there is more than one exhaust outlet, the reported sound level shall be for the loudest outlet. When there are two or more exhaust outlets separated by less than 12 in. (305mm), measurements shall be made on the outlet closest to the side or rear of the vehicle. (Figure 4). The sound level for the motor vehicles with the manufacturers' gross vehicle ratings of less than 6,000 LB (2,722 kg) except motorcycles, shall not exceed the following limit:
The statement stating extraneous ambient noise refers to noise coming from places other than the exhaust. For this reason, testing cannot be done in a sound-contaminated environment. It would be logical that a roadside or a highway would be a sound-contaminated environment.
(1) Sound Level Limit. The exhaust noise shall not exceed 95 dB(A).
This is very straightforward and should leave nothing to interpretation.
(2) Exemption. The exhaust noise of vehicles manufactured after 1967 may exceed 95 dB(A) if the replacement parts are no louder than the original equipment or "factory duplicate" system and the total sound level of the vehicle when tested in accordance with Sections 1040 through 1049 of this title complies with the limits in Vehicle Code Section 27205 for the year of manufacture of that vehicle.
This has been an attempt to clarify California Vehicle Code 27151 for many people who do not have an adequate understanding of this code. Bob's Muffler does not guarantee favorable results in defending one's self against a noise ticket since extenuating circumstances can affect the outcome in any court. Also keep in mind that it is your right to apply for an appeal.
View the CHP bulletin (Takes approximately 3 mins. to download @40000 kbps)
__________________
Brenspeed V3 Vortech SC, Brenspeed custom Tune- (395rwhp 380 TORQUE) installs done by GTR the best stang shop in Cali, FRPP 3.73 gears, Bassani x-pipe, JBA shorty heads, X3, Spintech's Super Pro axle back, Steeda oil sep.
S197winstang is online now   Reply With Quote
Old 03-29-2009, 11:51 PM   #22
S197winstang
http://www.bobsmuffler.com/noise.htm LINK
__________________
Old 03-29-2009, 11:59 PM   #23
S197winstang
OPEN THE CHP BULLETIN. USE IT IN YOUR FIGHT. Your car is an American classic not some foreign fart can that emits a raspy "harsh noise". Keep your cool and you will win.
__________________
Old 03-30-2009, 12:09 AM   #24
S197winstang
Default fron the cal vc.
27150.7. A court may dismiss any action in which a person is
prosecuted for operating a vehicle in violation of Section 27150 or
27151 if a certificate of compliance has been issued by a station
pursuant to Section 27150.2, or if the defendant had reasonable
grounds to believe that the exhaust system was in good working order
and had reasonable grounds to believe that the vehicle was not
operated in violation of Section 27150 or 27151
__________________
Old 03-30-2009, 12:31 AM   #25
StriderTacticaL
Vehicle: '04 Mustang GT
I'm gonna try to just get it signed off. ****ing jerkoff cop, I can't believe he stopped me just because he was bored. I was ****ing going like 30mph in 4th gear and in my neighborhood where I hear people are getting shot left and right...I get pulled over for my exhaust. I'm so surprised he didn't ask me to pop the hood or test my BAC just to see if he can bust me for as many things as possible
__________________
04 GT
K&N FIPK, Accufab 75mm TB & Trickflow plenum, Bassani SS catted X, Borla Stingers, 31 spline T-Lok w/Moser axles, FRPP 4.10's, Hurst billet/plus, MM XD LCA's, MM XL FLSFC, Cobra brakes, Sniper tuned.
StriderTacticaL is offline   Reply With Quote
Old 03-30-2009, 12:43 AM   #26
S197winstang
GOOD LUCK AND update us on the results. It is lame.
__________________
Old 03-30-2009, 01:23 AM   #27
StriderTacticaL
Well I stumbled across this thread:
http://www.iwsti.com/forums/how-inst...-now-what.html
Which seems to have a lot of useful info. Basically it seems that VC27151 and VC 27150 are very different and also whether the citation is marked under correctable or not makes a difference too.
I got a 27151 and I was marked under correctable. It seems that I have these options:
1. Just pay the fine (like $250 I heard)
2. Try to get it signed off by putting on the stock exhaust or etc and pay $25 or whatever it is now
3. Fight the ticket and use the above references as my defense. This option would be easier if I was cited for 27150 because I could just try and prove that my stingers were in good working order and not emitting an unusual noise other than the noise which it was designed to emit. I could also say the cop never looked under the car and checked.
__________________
04 GT
Old 03-30-2009, 01:03 PM   #28
GTRACER88
GTRACER88's Avatar
Vehicle: 2000 Mustang GT
I wonder whats SLP LM1 db
__________________
Mods: Too much and not enough
The only thing worse than socialism is ignorance.
GTRACER88 is offline   Reply With Quote
Old 03-30-2009, 04:18 PM   #29
PaintballFreak
PaintballFreak's Avatar
Vehicle: 2004, Mach 1
Just want to chime in to say that while I would be upset if I got a noise ticket, the law enforcing it can do some good. To prevent ridiculous things like this...
The Infamous Whistle Tips (They go WHOO WHOO)
They have to set a standard and it's difficult to say what is okay and what is not unless you just decide on a general noise level limit.
__________________
1999 GT - SOLD
2004 Mach 1 - Azure Blue
BBK Long Tubes - MAC O/R Prochamber - Borla Stingers
4.10s - Sniper Tuned
PaintballFreak is offline   Reply With Quote
95db, audio, borla, clips, db, flowtech, frpp, mustang, quiet, rating, regulation, sale, spintech, stingers, warlock, xs
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
