Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-11-2009, 10:28 PM   #1
jvog
Vehicle: 2002 Mustang GT
Default Windage tray with Teksid block
I was planning on using the Ford Racing windage tray with my teksid shortblock, but Lethal Performance said that the main studs on the teksid will need to be changed for the windage tray to fit properly. Seeing as my shortblock is already being built, does anyone have any more info on this? Is there a windage tray made just for the teksids?
__________________
2002 GT 5-Speed
V1 S-trim: 369 rwhp/361 rwtq
jvog is online now   Reply With Quote
Old 05-12-2009, 06:20 AM   #2
Chris98Gt
Chris98Gt's Avatar
Vehicle: 98 Mustang Gt
Ask them about the canton windage tray. Mine clears my arp main studs, its a cast block though. Lethal should know I would think.
__________________
98Gt with pro 5.0shifter, 3.73's Pi swap and stage 2 CompCams, BBK Lt's, catless H pipe, Flows. Procharged 8psi
Chris98Gt is offline   Reply With Quote
Old 05-12-2009, 11:32 AM   #3
jvog
I don't plan on reving my motor to the moon, 6500 rpms maybe a bit higher. I think I will hold out on the tray because my motor is already being built so I can't change the main studs.
Old 05-12-2009, 01:01 PM   #4
Stevecooper
Quote:
The Ford tray mounts to the main studs, I don't have the model #'s in front of me but ARP makes a set that works with the FRPP and stock 4V trays.
Get yourself a canton tray its like $70 and solves your problem.
__________________
2001 Bullitt
281CI Blue Printed Engine (Teksid, CP's, Manley Billit, Cobra Crank,) Foxlake Ported SVO heads, PI CAM's, kooks LT's, 2.3L Allen Twin Screw Blower, 63lb, SCT2800 MAF, Mcloed 8" Twin disk, Viper T-56, Griggs GR40 With Watt Link. SSR GT3's... and more.
535HP, 530TQ 12PSI .
11.77 128.5MPH (Times need some work )
5.4 Block 6L Stroker, 2V heads, Truck Intake. Sup now!
Stevecooper is offline   Reply With Quote
Old 05-12-2009, 01:01 PM   #5
Stevecooper
Here ebay with hardware.
http://cgi.ebay.com/ebaymotors/CANTO...3A1|240%3A1318
__________________
2001 Bullitt
Old 05-12-2009, 01:13 PM   #6
lizzyfan
Made Moderator
lizzyfan's Avatar
Vehicle: 98 GT Blumurder
Don't really need a windage tray as our cranks sit high enough
__________________
Tuned by Matt at Performance Evolution
432 rwhp
426 tq
DD-2008 Mazda3 Zoom Zoom!
1996-Ranger (AKA "Barney") RIP 305K!
lizzyfan is offline   Reply With Quote
Old 05-12-2009, 01:14 PM   #7
jvog
That's like double the cost of the ford one which is why I was trying to avoid it. I was told that the pickup tube will need to be modified to fit with the canton tray.
Old 05-12-2009, 05:35 PM   #8
Chris98Gt
Chris98Gt's Avatar
If you've got the stock pickup it won't. If your using a cobra or h/v pump with the 15/16ths pickup then all you have to do is cut the makeshift crankscraper off the pickup, took like 5 minutes max on mine.
__________________
Old 05-12-2009, 06:17 PM   #9
jvog
Oh ok. I'll be using the Ford high volume pump and pickup so I'll need to cut it off..
__________________
2002 GT 5-Speed
Old 05-13-2009, 06:34 AM   #10
Chris98Gt
Chris98Gt's Avatar
If its the 15/16ths tube and you use the canton tray you will. I think the ford tray is cut out to clear.
__________________
05, 46, 46l, 54, block, canton, directions, ford, gt, mustang, numbers, sale, teksid, tray, windage
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
