i am sure this has been asked before somewhere but i did do searching and couldnt find a straight asnwer.
i just got an 03 GT manual and i want to change the oil. i was reading around but got mixed opinions as to what type of oil is best to use, regular blend or synthetic. i was thinking of getting royal purple and i dont mind spending the extra money for it.
also as for an oil filter, what is the best one you can get? i was going to get a K and N filter but if they arent good or there is something better i want to get that.
lastly i dont have a manual, and i was wondering how manu quarts of oil are needed for an oil change of my model?
thanks for the help
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I use 6 quarts of 5w20 oil. Normally I use conventional, but this last time I switched to a synthetic blend. As far as the filter, I typically use fram. I am sure that there are guys on here that will swear by each of the products.
__________________
2004 Competition Orange Mustang GT
99/01 Cobra Front Bumper, Pypes O/R X pipe, Pypes Violator Cat-back
Vehicle: 02 Ford Mustang GT and 03 Crown Victoria PI
There is no best oil, but synthetics are better cause of the there cleaning agents and they can go longer without changing. Royal purple and k&n filter are both really good. Oh and mine takes 6qt. also
__________________
2003 Grey Crown Victoria Police Interceptor the DD stock
2002 Silver Mustang Gt not stock
JLT Cold air intake
Accufab 75mm Throttle Body & Plenum
Mac longtube headers
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
Steeda tri ax short shifter
H&R sport springs
Tokico HP Shocks & Shruts
18x9/18x10 Black chrome bullitt rims
SCT Xcal 2 tuner done by JMS Chip and perf. http://Centraltexasstangs.com
i would suggest stickin with whatever oil the previous owner(s) used. synthetics do last longer and are worth the money if you're willing to spend it. but if its not that big of a deal to you, then it would probably be better to use conventional, as to not "spoil" the engine (that is, if the previous owner(s) were using only conventional).
I use Royal Purple in mine. I was using Motorcraft 5w-20 until the warranty ran out then switched but still run 5w-20. As for a filter what ever you want I use Fram or K&N.
__________________
04 GT Screaming Yellow
K&N cold air, 24# injectors, SCT tune, SLP X-Pipe, Spin Tech cat back, Hurst shifter, 3:55 gears, & a couple of Autometer gauges.
03 Aviator Ivory Pearl
Stock for now
Theres been a lot of talk about how much oil is truely enough especailly for the later model new edges. The owners manual states 6 quarts but I've heard that basically it was discovered that 6 quarts is actually not quite enough and some people run 7. I've started to use a bit more than 6 since interestingly enough 6 quarts doesn't quite show full yet according to my dipstick.
