Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-02-2009, 10:24 PM   #1
Evenexchange
Vehicle: 2000 Mustang GT
Default Can't stand it!!!!!
For months now, I have been trying to figure out the ever present mystery amongst 99-04 mustang owners.
The squeak that occurs in the back of my car when going over an incline quickly, or going over a small bump slowly... anything that causes the rear end to raise up ever so slightly causes a squeaking noise that is both embarrassing, and annoying, especially when you have unloaded an entire $10 can of WD-40 on every rubber mount you can find underneath the rear of the car.
I have lubricated EVERYTHING. EVERY THING that has a rubber to metal connection, and I am starting to think that this noise MUST be from the shock itself... has ANYONE the slightest clue as to what this god d*mn noise is?!?!
Evenexchange is offline   Reply With Quote
Old 07-02-2009, 11:02 PM   #2
Tyler2001GT
Vehicle: 2001, Mustang, GT
I had this same problem and found it to be the emergency brake like catching up on the O ring it sits in on the drivers side. Go check it out.
Tyler2001GT is offline   Reply With Quote
Old 07-02-2009, 11:25 PM   #3
GT Tommy
If you lubricated every thing back there and are still hearing the squeaking sounds, I would replace the shocks. Sounds like you are hearing the sounds when the shocks are in the compression mode which is when ever you go over a bump. Good luck, Tommy.
GT Tommy is offline   Reply With Quote
Old 07-02-2009, 11:35 PM   #4
vanquish
I have the exact same problem. There was a thread about this about a week ago and someone said changing the shocks didn't do anything.
__________________
2000 Ford Mustang GT
Vortech V1 S Trim
JE 194329 Forged Pistons
CRS 5933F30 Forged Rods
Fel-Pro Gaskets & Bolts
Ford Racing 11" Clutch
Sniper Tuned
Pypes Violators
Mac Prochamber
B&M Shifter
Subframe Connectors
vanquish is offline   Reply With Quote
Old 07-05-2009, 09:46 PM   #5
laddanator
Default Same here
I have a 98 Cobra and I two suffer from this problem and new shocks didnt help but I have notice the 96-04 mustangs are squeaky. Like to know a fix myself
laddanator is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
